Ciao ragazzi, oggi testando un sensore di pressione BMP085 con la libreria di Adafruit mi sono accorto di un comportamento alquanto anomalo nei dati restituiti come output nel serial monitor, sto provando con lo stesso errore si presenta con l'IDE 0023 di cui le foto... che con l'IDE 1.5
Veniamo al dunque con questo codice:
#include <Wire.h>
#include <Adafruit_BMP085.h>
This is an example for the BMP085 Barometric Pressure & Temp Sensor
Designed specifically to work with the Adafruit BMP085 Breakout
----> https://www.adafruit.com/products/391
These displays use I2C to communicate, 2 pins are required to
interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
// Connect VCC of the BMP085 sensor to 3.3V (NOT 5.0V!)
// Connect GND to Ground
// Connect SCL to i2c clock - on '168/'328 Arduino Uno/Duemilanove/etc thats Analog 5
// Connect SDA to i2c data - on '168/'328 Arduino Uno/Duemilanove/etc thats Analog 4
// EOC is not used, it signifies an end of conversion
// XCLR is a reset pin, also not used here
Adafruit_BMP085 bmp;
if (!bmp.begin()) {
Serial.println("Could not find a valid BMP085 sensor, check wiring!");
while (1) {}
Serial.print("Temperature = ");
Serial.print(bmp.readTemperature());
Serial.println(" *C");
Serial.print("Pressure = ");
Serial.print(bmp.readPressure());
Serial.println(" Pa");
// Calculate altitude assuming 'standard' barometric
// pressure of 1013.25 millibar = 101325 Pascal
Serial.print("Altitude = ");
Serial.print(bmp.readAltitude());
Serial.println(" meters");
// you can get a more precise measurement of altitude
// if you know the current sea level pressure which will
// vary with weather and such. If it is 1015 millibars
// that is equal to 101500 Pascals.
Serial.print("Real altitude = ");
Serial.print(bmp.readAltitude(101500));
Serial.println();
ottengo il risultato in figura 1.
con questo invece :
#include <Wire.h>
interface
Serial.begin(57600);
if (!bmp.begin()) {
while (1) {}
Serial.print(bmp.readAltitude(102024));
Serial.println();
Serial.println(500);
ottengo il risultato in figura 2.
Da notare che la diversità nei due programmi sta solo nella velocità della seriale 57000 contro 9600 e nella pressione bmp.readAltitude(x)
Anche la dimensione dell'eseguibile cambia enormemente come descitto in figura 3, come mai ? sto sbagliando io oppure ho trovato un bug?
p.s. Il micro lavora ad 8Mhz con il bootloader della 2009 anche se è montato su una luigino 328 con il quarzo a bordo, anche se non dovrebbe essere influente la cosa meglio specificarlo xD
grazie a tutti.
