Hello All ,programming is not my strength ( electronics is)... I would like to display what i have coming out of my soft serial port so i can see on the lcd... I have been able to type into serial monitor and shows on lcd, but how to show what is coming out of soft serial seems to avoid me...
I want to make a small device that i can send a command ( text or number to my Bluetooth on the uno and be able to check what it receives on the lcd, works ok at present i can monitor on the serial monitor , just want to add lcd so was portable.... My code below ( I bet it is something very easy I am just missing) ?
#include <SoftwareSerial.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
SoftwareSerial mySerial(3, 2); // RX, TX
#define text
#define text=myserialvoid setup()
{// set up the LCD's number of columns and rows:
lcd.begin(16, 2);//added
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
}mySerial.begin(115200);
mySerial.println("test comms");
}void loop()
if (mySerial.available())
Serial.write(mySerial.read());
if (Serial.available())
mySerial.write(Serial.read());
delay(100);
lcd.clear();
lcd.print("need to see what bluetooth received ");// this is where i would like to send soft serial so i can see it on the lcd ???
