I am using the 1.5.3 IDE to try and upload to an Arduino due but I keep getting this error. ( it makes no difference if the board is actually connected or not) I believe it to be some issue with the IDE or my installation of it.
Hoping for help
Arduino: 1.5.3 (Linux), Board: "Arduino Due (Programming Port)"
The "line" you pasted in the first post shows that the arduino-1.5.3 folder is
"burried" in three higher folders, which are repeated several times in this
very long "command", quite possibly making it too long to process.
So, move (cut and paste) the arduino-1.5.3 folder to the root of the drive
(not in any other directory), and it will probably work.
Start with the Due not connected to anything else.
Connect the Due Programming Port to the PC USB port.
Using the Arduino IDE version 1.5.4r2 (for Due), select
the Board as Due Programming Port, and the Comm Port
that the OS allocated to your Due.
Compile and load the Blink Sketch.
Previously, you should have downloaded the zip file of the
IDE and unzipped it, and moved the "arduino-1.5.4" folder to
the root of your hard drive (in Windows).
The first attachment of the Due will look for a driver, as I recall.
For the download, Google
Arduino IDE for Due
and follow the instructions here:
And, for the Due, read this:
Hopefully,this will help.
If not, please ask more specific questions.
Cheers, Gary
