Topic: Prototype PMU: measure phase difference of two sine waves using arduino (Read 4153 times) previous topic - next topic
sudiptakar484
Code: [Select]
if (data_available == true);
Lose the ; that makes the if statement not work.
after removing the ; there is no output on serial monitor
cattledog
Quote
Your zero cross interrupt is not being triggered. We are now back to hardware, and what you have for an input signal to the interrupt pins?
You chose not to use the optocoupler for zero cross detection. You have not demonstrated that you have applied the direct signal reading method correctly. Please post a sketch of your circuit.
sudiptakar484
This is the circuit I have used, please check this
Grumpy_Mike
1) The 1M resistors are way to high to correctly trigger the logic inputs.
2) You have no protection for negative voltages. I would check those pins still work. Enable the pull up resistors, disconnect that circuit and dab a ground wire on both the inputs and see if you get printing.
3) The timing between those two signals do not in any way indicate any sort of phase shift. So there is nothing to measure except the small time between the two signals reaching the triggering threshold when and if you get them triggering.
sudiptakar484
then how can I proceed further, I followed the AVR application note, as per the note the clamping diodes will clamp voltages within 0-5 V.  help me please
Grumpy_Mike
No you didn't that note is only for experts it is not a beginner's guide. There is a lot you have to understand. First exactly what phase shift do you want to measure?
sudiptakar484
I want to measure the phase difference between the voltage and the current waveform
Grumpy_Mike
Then use a circuit that will give you a zero crossing signal for current and for voltage. That is two measurements not just one.
Have a look at the https://openenergymonitor.org site.
sudiptakar484
If I want to measure the ac voltage and ac current magnitude using hall sensors, how to do that?
Grumpy_Mike
A hall sensor will only measure current it will not measure voltage.
Hall current probes only work for large currents, how much current do you have?
Did you get to this page:- https://learn.openenergymonitor.org/electricity-monitoring/ac-power-theory/introduction
Or even this page https://learn.openenergymonitor.org/electricity-monitoring/ctac/how-to-build-an-arduino-energy-monitor
