Topic: How to use Virtual Wire Library (Read 3817 times) previous topic - next topic
DrDiettrich
You lost part of the source code, by copying from one post to another.
RakshithNarun
So what is the mistake i have  done in my code
Should i change my code from
Code: [Select]
vw_send((uint8_t *)msg,1);
to
Code: [Select]
vw_send((uint16_t *)msg,1);
GrooveFlotilla
No.
You need to send both bytes of the int variable.
Some people are like Slinkies.
Not really good for anything, but they bring a smile to your face when pushed down the stairs.
RakshithNarun
pls some help to write the code for the above said example
GrooveFlotilla
RakshithNarun
So this is the correction what u are suggesting
Code: [Select]
vw_((uint8_t *)i,2);
GrooveFlotilla
#21
Mar 14, 2017, 03:20 pm Last Edit: Mar 14, 2017, 03:23 pm by Groove
Yes.
As a noob , you have to wait five minutes between forum posts. Why don't you use those minutes to try things out, or doing more reading?
RakshithNarun
I am trying to learn from different examples, but i am not able find enough examples or i am not able understand the existing code
GrooveFlotilla
So, how did the mod in reply #20 go?
jremington
#24
Mar 14, 2017, 05:21 pm Last Edit: Mar 14, 2017, 05:22 pm by jremington
Quote
You can ask questions on this forum. Post a line of code that you don't understand and ask for an explanation.
We generally recommend that people start with the very simple examples provided with the Arduino IDE, to learn the language and the special features of the Arduino, before starting a project which uses advanced techniques.
RakshithNarun
Thanks for all your help guys
As you said i tried an example and came up with this code
This is for the transmitter side
Code: [Select]
#include<VirtualWire.h>
int xi=A0;
int xa,xo;
char *controller;
  pinMode(xi,INPUT);
  vw_set_ptt_inverted(true);
  vw_set_tx_pin(4);
  vw_setup(4000);
  Serial.println("Start");
  xa=analogRead(xi);
  Serial.println(xa);
  if (xa<=400)
    controller="2";
    Serial.println("clock");
  else if(xa>=400 & xa<=800)
    controller="1";
    Serial.println("stop");
  else if(xa>=800)
    controller="0";
    Serial.println("anticlock");
  Serial.println("");
  vw_send((uint8_t *)controller,strlen(controller));
  vw_wait_tx();
The A0 is connected to a potentiometer
This is the code for the Receiver side
Code: [Select]
int en1=9;
int i1=7;
int i2=6;
  pinMode(en1,OUTPUT);
  pinMode(i1,OUTPUT);
  pinMode(i2,OUTPUT);
  digitalWrite(en1,1);
  Serial.println("setup");
  vw_set_rx_pin(12);
  vw_setup(4000);
  vw_rx_start();
  uint8_t buf[VW_MAX_MESSAGE_LEN];
  uint8_t buflen=VW_MAX_MESSAGE_LEN;
  if(vw_get_message(buf,&buflen));
    if(buf[0]=='2')
      digitalWrite(i1,1);
      digitalWrite(i2,0);
    else if(buf[0]=='1')
      digitalWrite(i1,0);
      digitalWrite(i2,0);
    else if(buf[0]=='0')
      digitalWrite(i1,0);
      digitalWrite(i2,1);
On the reciever side  I am using an Hbridge module
This code is working fine for me
In this code I am able to send 8bit data using single variable
Now what i want to learn is that how to transmit and receive 2 variables
And also transmit and receive data of 16bit length
How to edit the existing code
Thanks for your help
GrooveFlotilla
Hint: a 16 bit variable consists of two bytes,
jremington
#27
Mar 15, 2017, 03:58 pm Last Edit: Mar 15, 2017, 04:00 pm by jremington
Quote
I'm sure it does, but it is clear that you don't understand it. You need to understand your own code before you can move on. If we write the code for you, you won't understand it.
For example, the following line already sends as many bytes as there are in the character array "controller". Can you figure out why?
Code: [Select]
However, in the receiver code, you ignore the received length of the buffer and just examine the first character.  Why are you ignoring "buflen"?
Code: [Select]
    if(buf[0]=='2')
RakshithNarun
Thanks for telling me to learn the
That is the main reason I didnt explain my entire project
I only explained a part of my project
Thanks again
U asked me how does the length of controller works
controller is a char variable, hence the end of the string is mensioned using a null character(/0)
And for your next question, y i am ignoring buflen
i thought i was sending only 1 char(0,1,2), hence i left that part
Are u specifying there is a significance for buflen
Please teach me
Thank you
RakshithNarun
I am finding a small problem after using the following code
Code: [Select]
//tx code with analog stick test 4
char *controller;
int xi=A0;
int yi=A1;
int xa,ya,xo=1,yo=1;
  vw_set_tx_pin(12);
  vw_setup(4000);
  pinMode(xi,INPUT);
  pinMode(yi,INPUT);
  //code for converting
  //analog stick values to 0,1,2
  xa=analogRead(xi);
  ya=analogRead(yi);
  if (xa<=600)
    xo=2;
  else if (xa>=600 & xa<=900)
    xo=1;
  else if (xa>=900)
    xo=0;
  if (ya<=400)
    yo=2;
  else if (ya>=400 & ya<=600)
    yo=1;
  else if (ya>=600)
    yo=0;
  //code for transmitting the analog stick control input
  if (yo==2)
    //forward
    controller="0";
  else if(yo==0)
    //backward
    controller="1";
  else if(yo==1 && xo==2)
    //right
    controller="2";
  else if(yo==1 && xo==0)
    //left
    controller="3";
    //stop
    controller="4";
  digitalWrite(13,HIGH);
  vw_send((uint8_t *)controller,1);
  vw_wait_tx();
  Serial.print("controller:");
  Serial.println(controller);
  digitalWrite(13,LOW);
  delay(200);
the led at pin 13 should blink every 200 ms, which is 5 times a minute
this is to check if the transmission has completed successfully or not
But my led just staying on
It worked once
Can u pls help me with this
