Composite Video Generating
I am working on generating composite video with the due. It uses the dac, and it works great already. I will post some photo's tomorrow.
Here are some pictures. (Yes, I use a camera as tv screen, since I have no tv in my room) The generated signal is 150x287, and uses 'fake' progressive: It only outputs one field.
Edit: ATM I am trying to get color working.
Hmm, implementing color seems to be very hard. I don't understand what I need to generate from the RGB values. Since there is a color burst + the signal itself.
Be careful about connecting the output of the DAC directly to a video input, as video inputs usually have a low impedance (75 ohms) and some of us have broken our DACs by connecting them directly to low impedance loads. Use a buffer amplifier or emitter follower.
Generating colour is very complicated. The colour subcarrier needs to be at a very specific frequency (3.579545 MHz for NTSC or 4.433619MHz for PAL) and I doubt the DAC can go that fast.
stimmer:
I have it connected to my scope too (which has 1M impedance). But anyway, I could try making a R2R ladder or something. That would be much faster. But I am not sure if I have the right resistors.
Gericom:
I'm right yo you must have all parallel connected, so the smalest resistor will beat all other if you connect it and messure the impedance value you will get ~75 Ohm even with the 1M impedance. God will be an operational amplifire as voltage follower between the DAC and the rest of the connections or something else how has an high input impedance and an low output impedance.
The more I think about this the more I wonder if it might actually be possible - an R-2R ladder on the external memory pins (34-41) together with DMA should work reliably at 10.5MSPS and may even go as high as 21 or 28MSPS (I learned that doing the VGA library). The dealbreaker would be how close to the exact colour subcarrier frequency you have to get. In my experience, with old CRT TVs you have to be very accurate, but more recent LCD panels have more tolerance for the frequency and amplitude of the colour subcarrier being wrong.
stimmer:
That would be awesome, but first I need to add an op-amp to my ladder, otherwise the signal drops when connecting to my camera. Can you give me some lm#### ic numbers?
Edit: I ordered some samples of the AD811 (AD811 Datasheet and Product Info | Analog Devices). It seems to be a good one. I hope I will get them in a week or 2.
I got it working on my r2r ladder without an op-amp now (I mean the signal b/w not color yet). I only needed to change the pin numbers.
Can someone tell me how to add dma?
I've just found some resistors for an R-2R ladder but they are only 1% tolerance. I was going to measure them more accurately and select some for the ladder, otherwise things start going wrong after 5 bits. Even then I think there will be too much noise on the digital outputs for full 8 bit accuracy. I'll see how well I can do.
DMA for the external memory port is quite hard to set up as it is AHB DMA - I use it in the VGA library but the code is impossible to follow :grin: I'll try and do a simpler example once I've got the ladder done.
stimmer:
I have 8 bit now. With 5% tolerance. (R is 10K each. I use 2 of them for the 2R. I know that this resistor is a bit too high)
Hmm, too bad. Isn't dma just setting a source and a destination pointer? On the ds for example there are functions like these:
void MI_DmaCopy32(u32 dmaNo, const void *src, void *dest, u32 size);
Which you use like this:
MI_DmaCopy32(3, &px[0], VramPixels,512 * 192);
Aren't there such functions on the due?
Here is an example of a picture generated with the due. (It is captured in jpeg using the camera I use for viewing it, so not the best quality)
With 5% resistors the R-2R ladder may lose too much accuracy. 5% of 255 is almost 13 which is a 4-bit number, so you could lose 4 bits of accuracy out of the 8, which is too much. Try connecting the analog output of the ladder to an analog input on the Due, then write a sketch which outputs 0-255 onto the ladder and reads the value on the analog input. You might find that the ladder isn't monotonic (sometimes when the input goes up by 1 the output voltage goes down instead of up).
THe DMA needs to be continuous (a bit like an audio buffer would be, just a lot faster) which is why it's more complicated than just DMAing blocks of memory.
stimmer:
Yea, but it works good enough for now. I will use other resistors (1%) later on.
Oh, okay. I realize how it need to work now. I will try to understand your code, since I only need to change the frequency and the source pointer.
Here's the sketch I used to check my ladder:
char pins[]={34,35,36,37,38,39,40,41};
void writeval(int v){
  for(int i=0;i<sizeof(pins);i++){
    digitalWrite(pins[i],v&1);
    v>>=1;
  analogReadResolution(12);
    pinMode(pins[i],OUTPUT);
  int l=0;
  for(int i=0;i<(1<<(sizeof(pins)));i++){
    writeval(i);
    delay(10);
    int m=analogRead(0);
    printf("%d : %d  d=%d\n",i,m,m-l);
    if(m<l)printf("!!!!!!ERROR!!!!!!!!!! non-monotonic\n");
    l=m;
  delay(2000);
If you get errors then just swap the resistors around until they go away.
I've tried some things with dma, but now my arduino doesn't work anymore. I have seriously no idea what's the problem.
Edit: It works again. I pressed the erease and the reset button at the same time, and were able to upload a sketch again. After that everything worked well again.
Gericom:
Lucky men, I know this kind of happiness...
Markus_L811:
Gericom:
Yea, first I thought it has broken. But then I just tried some random things, and then by purpose the bossac com port connected to my pc.
By the way, I changed the loop (with asm code) and now it is 330 px width.
Success! 8) :grin: XD
stimmer:
:astonished: Cool! May I have your code?
