Hi. I bought an Arduino Mega and an EasyVR Module. I follow the pin configuration of the module like RX(EasyVR) to Pin12(Arduino) and TX(EasyVR) to Pin13(Arduino)..
My problem is everytime I pressed the connect button on the EasyVR Commander it says
"A AVR/Arduino Mega device has been found, but the 'bridge software is not responding or it is outdated.
You need to manually download the updated 'bridge' software to the device"
I bought an easyvr module only.. it doesnt have any jumper option on it.. thanks for the help!! I'll just wait for your reply after you try the components.. thanks a alot!
Ah... just the module. Well then. Out of the gate, you state that you have the ERx (EasyVR) -> Pin12 (Mega) and ETx -> Pin13. This is backwards according to the sketch:
EasyVR Bridge
Soft-connects pins 0 (Rx) to 13 (ERX) and 12 (ETX) to 1 (Tx)
with roughly 5us sample rate, for connecting with the GUI.
Try switching the jumpers on the Mega and see what happens.
I fired up my EasyVR Shield with no issues on a Mega.
me too have the same problem here.. i connected the erx pin(easyvr) to 0 (mega) and etx pin(easyvr) to mega and uploaded the bridge program.. bridge program gives "easyvr not started"output on the serial monitot.. and when i try to connect using commander then it says
You need to manually download the updated 'bridge' software to the device(see instructions)"
pls help.. this is for my btech project and i have to complete it within a month
