I'm struggling to get I2C running on my digipot. Maybe someone can help:
I am using an Arduino Uno R3 and have connected Pin 4 and 5 for the I2C data transfer. I am using 5V from the Arduino output. I have used the MCP4442 digipot, specs can be seen here (extensive, but I seem to miss the 2 important lines!):
When I power on the arduino, the rheostat goes to 50kOhm which is the initial mid wiper position (so seems to work as defined). Anyway I also tried connecting 2 Pullups resistors of 10kOhms, but no change.
I tried to look close on this tutorial. Especially as it uses also a MCP chip and the chip has even thesame ID (at least to address one pot).
Here is my Sketch:
// written to debug MCP4442
byte wiperSetting = 0x00; // min value
//byte wiperSetting = 0x40; // max value 7Bit
//byte wiperSetting = 0x80; // max value 8Bit - do not use
#include "Wire.h"
Wire.begin();
//Set all 4 Digipots to same value!
Wire.beginTransmission(0x2C);
Wire.write(wiperSetting);
Wire.endTransmission();
Wire.beginTransmission(0x2D);
Wire.beginTransmission(0x2E);
Wire.beginTransmission(0x2F);
delay(2000);
This addresses the chip if the address pins 0 and 1 are connected to ground. Then you send the wiper setting without addressing the register. This does not work. To set the first wiper:
Wire.write(0x00); // write to address 0 (wiper 0)
Wire.write(0x00); // lower 8 bits of data value
For wiper 1 it is:
Wire.beginTransmission(0x2C); // same address!
Wire.write(0x10); // write to address 1 (wiper 1)
The format is described on page 61 of the datasheet.
I tried that yesterday night, but unfortunately didn't have success. I'm wondering if my breadboard connections might have an issue. Power is fine, otherwise the wipers wouldn't move to default settings and TSSOP board soldering was also crosschecked. Will check breadboard again today evening and post a pic with connections. It shouldn't be that hard to get this small thingy running
Any other suggestions what I could have done still welcome. Turnaround with Arduino is so great when comparing this to my old days in PICs (many years ago). Works like a charm - I'm completely impressed.
