I draw a PCB external board to insert to the Arduino Mega1280 board. But, I need take out the external board every time when I have uploaded my program to that board. Otherwise, the error will appear avrdude: stk500_getsync(): not in sync: resp=0x00. How can I solve that problem. Please help me.
I just connected the socket to Serial line without any IC. However, I am concern one thing that is I drew a wrong reset circuit to Reset pin, +5V -> push button parallel with 10uF capacitor -> reset pin parallel a resistor -> ground. I measure the voltage of the reset pin is around 2.65V. Is it that part to make a fault?
But I found my board is quit unstable because after I connected AREF to 3.3V, then upload the program to the Mega board, it would fail to upload too. The error is ser_send(): write error: sorry no info avail. P.S. in this case, I had not insert my external board to Mega. Is it normal?
littleming:
Very likely, but your drawing is almost impossible to read, even when blown up to 200% size. Here is the link to the standard arduino Uno board so you can study how they have the reset system wired up.
OK. I read the schematic diagram for Mega1280. I saw the reset circuit is connect to push button, then ground. My question is the reset pin is floating without press button. Is it OK or connect a pull up resistor to Vcc may be better?
And I upload again my schematic again. It is a eagle file. Thank you very much.
The table for the pin header connecting to Arduino board is showing below:
POWERARDUINO = Power part of Arduino board
ANALOGIN1 = Analog in Pin 0 ~ 7
DIGITAL = Digital pin 22 ~ 53
PWMARDUINO1 = AREF+GND+PWM pin 13 ~ 8
PWMARDUINO2 = PWM pin 7 ~ 2 + TX + RX
PWM pin 2 ~ 13 ARDUINO are connected to ULN2003A.
Analog in pin 13, 14, 15 are connected to G sensor x , y, z respectively.
some digital pins are connected to ultra sound sensor and IR sensor.
But when I test my external board, I had not insert any IC to it.
I forgot mention that the arduino board and my board is running normally after upload the program to the Mega board with empty state. The board just fail when I upload the program to the Mega board if I insert others board.
