Hi
I am trying to do an event countdown with the arduino. I am very new to the programming language and am trying to feel my way through.
I am using a ds1307 and I made some code that is 'supposed' to perform a calculation but it is returning the wrong values.
I used the code from here https://sites.google.com/site/tronixstuff/home/arduino-tutorial-series-files/example7p3.pde?attredirects=0
as the base for my code which sets up the ds1307 and reads the time from it and you can manually set the time. The reason I used this code is because the ladyada tutorial the rtc1307 is set automatically.
I then wrote some code that tries to take the date and perform a calculation on it.
Because the number it returns is higher than 65,535 I am not sure what to use. Do I use int or long in my code instead of byte and word?
My second issue stems from the fact that the data extracted and printed to the serial monitor for the year is only 2 digits because it is a byte. I need to return the entire year for my calculation to work. It uses the whole 2011 as part of the equation. Which is why I have added +2000 to my equations.
I have set the ds1307 to the 2/9/2011 and the number it should be returning is 114 days. But the days and daysf values which are printing to the serial monitor are incorrect. The results should be days=734781 and daysf=734895. It currently returns days=13889 and daysf=13999 and returns 110.
The code for my calculation is below.
I created 2 global bytes called yearA and monthA which stands for year adjusted and month adjusted and 2 bytes called days and daysf which stands for days future.
The problem probably lies in my use of calculation functions or the way I have set up the storage for the integers. Could someone please tell me how to debug it easier? I really need to see what value is actually being used in the calculation for year and yearA and month and monthA.
if (month <3) {//if month is January or February subtract 1 from year and use in yearA
yearA=year-1;
else {
yearA=year;
if (month <3) {//if month is January or February add 12 to the month and use in monthA
monthA=month +12;
else {
monthA=month;
// Serial.println(dayOfWeek, DEC);
/*The following calculates days to set countdown with the following formula
If month is 1 or 2 add 12 to the month and subtract 1 from the year
then apply the following formula
365*year + year/4 - year/100 + year/400 + date + (153*month+8)/5 all integers rounded down
Do this for the current date and the future date and subtract one from the other then
display the days remaining on the 7 segment display*/
days=365*(yearA+2000) + (2000+yearA)/4 - (2000+yearA)/100 + (2000+yearA)/400 + dayOfWeek + (153*monthA+8)/5;
/* Below is the function to perform the calculation on the date till the event.
I have set the now.year because I will always be counting down till the
25th December in the current year. Just alter the year and month and day values
for other dates*/
daysf=365*(year+2000) + (2000+year)/4 - (2000+year)/100 + (2000+year)/400 + 25 + (153*12+8)/5;
Serial.println (days, DEC);//for debugging
Serial.println(daysf, DEC);//for debugging
Serial.println(daysf-days);//This is the number I will shift out to the7 segment leds.
Sorry to ask for help on something that takes so long to explain! I am pulling my hair out. Manually the calculations works perfectly.
Thanks
Steve
