Hi all,
I'am a begginer on Arduino and I have a trouble with the communication between the card and my computer.
I work on windows 7 and I followed the instructions to installt the card driver. After the installation the card (Arduino UNO) is now called "Communication Port (COM3)" on the Windows device manager (Yes I come from France XD).
I used the "Arduino Uno.inf" file.
I want to control a servo-motor with instructions of positions that I enter in the serial monitor.
Now I try to upload the folowing code to my board :
#include <Servo.h>
Servo myservo;
int ReceptionOctet=0;
int ReceptionNombre=90;
int SaveReceptionNombre=0;
myservo.attach(2);
myservo.write(90);
if (Serial.available()>0)
ReceptionNombre = 0;
while (Serial.available()>0) {
ReceptionOctet= Serial.read();
Serial.print("ReceptionOctet : ");
Serial.println(ReceptionOctet);
ReceptionOctet=ReceptionOctet-48;
Serial.print("ReceptionOctetASCII : ");
if ((ReceptionOctet>=0)&&(ReceptionOctet<=9)) ReceptionNombre = (ReceptionNombre*10)+ReceptionOctet;
delay(1);
if(ReceptionNombre != SaveReceptionNombre)
if(ReceptionNombre<0) ReceptionNombre = 0;
else if (ReceptionNombre>180) ReceptionNombre = 180;
Serial.print ("Nombre recu= ");
Serial.println(ReceptionNombre);
myservo.write(ReceptionNombre);
SaveReceptionNombre = ReceptionNombre;
delay(20);
--> First I tried the reaction of the program when the servo-motor is not connected to the card.
I write for example "150" in the serial monitor and the card answers good (In French Sorry again ^^ ) :
ReceptionOctet : 49
ReceptionOctetASCII : 1
ReceptionOctet : 53
ReceptionOctetASCII : 5
ReceptionOctet : 48
ReceptionOctetASCII : 0
Nombre recu= 150
But when I connect the servo-motor (Hitec HS-422 : Red wire on 5V, Black wire on GND and Yellow on PWM 2) I immediatly have an error :
java.io.IOException: Input/output error in writeArray
at gnu.io.RXTXPort.writeArray(Native Method)
at gnu.io.RXTXPort$SerialOutputStream.write(RXTXPort.java:1124)
at processing.app.Serial.write(Serial.java:517)
at processing.app.Serial.write(Serial.java:540)
at processing.app.SerialMonitor.send(SerialMonitor.java:200)
at processing.app.SerialMonitor.access$100(SerialMonitor.java:32)
at processing.app.SerialMonitor$3.actionPerformed(SerialMonitor.java:89)
at javax.swing.JTextField.fireActionPerformed(JTextField.java:492)
at javax.swing.JTextField.postActionEvent(JTextField.java:705)
at javax.swing.JTextField$NotifyAction.actionPerformed(JTextField.java:820)
at javax.swing.SwingUtilities.notifyAction(SwingUtilities.java:1636)
at javax.swing.JComponent.processKeyBinding(JComponent.java:2851)
at javax.swing.JComponent.processKeyBindings(JComponent.java:2886)
at javax.swing.JComponent.processKeyEvent(JComponent.java:2814)
at java.awt.Component.processEvent(Component.java:6040)
at java.awt.Container.processEvent(Container.java:2041)
at java.awt.Component.dispatchEventImpl(Component.java:4630)
at java.awt.Container.dispatchEventImpl(Container.java:2099)
at java.awt.Component.dispatchEvent(Component.java:4460)
at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1848)
at java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(DefaultKeyboardFocusManager.java:704)
at java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(DefaultKeyboardFocusManager.java:969)
at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:841)
at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:668)
at java.awt.Component.dispatchEventImpl(Component.java:4502)
at java.awt.Window.dispatchEventImpl(Window.java:2475)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Here my serial port has disapeared in the menu and most of time I must disconnect the card from my computer to get it back.
Other things I noted :
- When the motor is connected and the serial monitor is opened the windows device manager screen seems to be refreshed every 5seconds as the card was disconnected and reconnected successively....
- I tried other pins on the card to connect the yellow wire of the servo motor. On pins 2 to 7 I can upload a program to the card when the servo-motor is connected. But on pins 8 to 13 I have the following error message when i try to upload : avrdude: ser_open(): can't open device "\.\COM3"
Thanks for your help !!!
Olve
