Topic: Using mills() instead DELAY timers (Read 2447 times) previous topic - next topic
nik11
 I am new to Arduino development. I want to use millis function instead delay because delay is blocking further execution of program.
Programme description: In this code i want to control 2 solenoid valves with ds3231 RTc alarm and also with infrared remote control button pressed.
But when i press one button for valve ON progam does not turn valve on.
plz check this program and correct my mistake.
#include <DS3231.h>
#include <IRremote.h>
#include <IRremoteInt.h>
#include "IRremote.h"
#define LED1 2
int receiver=6;
IRrecv irrecv(receiver);     // create instance of 'irrecv'
decode_results results;      // create instance of 'decode_results'
#define VALVE1 7
#define VALVE2 12
DS3231  rtc(SDA, SCL);
Time  t;
//-------------millis timer----------------------------------
unsigned long last1 = millis();
  irrecv.enableIRIn(); // Start the receiver
  rtc.begin();
  pinMode(VALVE1,OUTPUT);
    pinMode(VALVE2,OUTPUT);
{ t = rtc.getTime();   // Get data from the DS3231
  delay(200);
   if (irrecv.decode(&results)) // have we received an IR signal?
    translateIR();
    irrecv.resume(); // receive the next value
  //------ALARM FOR AUTO WATERING GARDEN----
       //MORNING Routine FOR VALVE========
    if (t.hour == 16 && t.min == 15 && t.sec == 00)  //Open valve1 8AM morning
     {void G_valve1On();}
    if (t.hour == 16 && t.min == 20 && t.sec == 00)  //close valve1 8:10AM morning
     {void G_valve1Off();}
//---------FUNCTIONS-----------------------------
   //IR COMMAND FUNCTIONS
   void translateIR()
       switch(results.value)
        case 0x843509F6:         //valve 1 turn on for 10minute delay
            if (millis() - last1 >600000)  //when remote button pressed valve turn on for 10min
              {  G_valve1On();
              Serial.println("valve ON");
              G_valve1Off();
              Serial.println("valve off");
               delay(250);
        case 0x84350AF5:                 //2nd button for 15 min delay
              G_valve2On();
            //Serial.println("valve on 15minutes...");
         //Help me to use MILLS FUNCTION.
              G_valve2Off();
            //Serial.println("valve off");
             delay(250);
       delay(300);
  //----VALVES- FUNCTION------
  void G_valve1On()
      digitalWrite(VALVE1,HIGH);
     Serial.println("...turning valve1 on...");
  void G_valve1Off()
     digitalWrite(VALVE1,LOW);
     Serial.println("...turningvalve1 off...");
   void G_valve2On()
      digitalWrite(VALVE2,HIGH);
  void G_valve2Off()
     digitalWrite(VALVE2,LOW);
J-M-L
Code: [Select]
              {  G_valve1On();
              G_valve1Off();
               delay(250);
if you follow this step by step, what do you think this does? (and where is last1 updated)
also if you are unlucky and your code misses the exact second to open or close - what will happen?
Code: [Select]
Also what do you think the notation {void G_valve1On();} or {void G_valve1Off();} means?
Please correct your post above and add code tags around your code:
[code] // your code is here [/code].
It should look like this:
Code: [Select]
(Also press ctrl-T (PC) or cmd-T (Mac) in the IDE before copying to indent your code properly)
Please do not PM me for help,  others will benefit as well if you post your question publicly on the forums
Pas de messages priv├ęs SVP
