Arduino Forum
Using Arduino => Networking, Protocols, and Devices => Topic started by: streetHawk on May 03, 2012, 05:56 pm
Title: Query please guide
Post by: streetHawk on May 03, 2012, 05:56 pm
I am having some queries regqrding the M DB protocol , in the specification the peripheral addresses are defined as
00001xxx (08H) for eg a changer : upper 5bits[7,6,5,4,3] are used for addressing and lower 3bits[2,1,0] for commands.
Suppose i need to send a Poll command (0BH) to the changer peripheral how should i construct the word.
(00001xxx | 0xB) = 0xB
00001xxx
00001011
00001011 (0B)
Am i intrepreting correctly. Also do i need to send this with the mode bit (9th bit) set as address and is there any checksum to be sent after the poll command on the serial bus.Please suggest.
Hwk
Title: Re: Query please guide
Post by: johnwasser on May 03, 2012, 06:38 pm
Your problem there is that 0x0B doesn't fit in three bits.  :(
Do you have a pointer to the documentation?  Perhaps someone else reading the document would be able to interpret it for you.
Post by: robtillaart on May 03, 2012, 09:12 pm
from the example I assume the Poll command is 0B00000011 iso 0xB  ==> ANDing 0B00000011 with 0B00001xxx gives 0B00001011 = 0x0B
00001xxx
00001011
00001011 (0B)
if the operation is an OR the answer could also be 00001111 !  if the first x would be an 1 (by accident or ...)
The proper way to OR the addresses and commands is
WORD = ((ADDR<<3) & 0B11111000) | (CMD & 0B00000111);
as the address is often just zero based, and the command is 0..7 the optimized Arduino code will look something like
int w = (address << 3) | command ;
(does this make sense to you?)
Post by: streetHawk on May 04, 2012, 03:21 am
Thanks for the response John & Robtillaart,
The document I'm referring to is this link
http://www.vending.org/technology/MDB_Version_4.pdf
Please refer to this document On pg-11 the addresses are detailed and pg-14 depicts a Typical session example & Pg-29 lists all the cmd .
Based on this what is ur suggestion
Post by: robtillaart on May 04, 2012, 08:56 am
from the PDF
Address Definition
00000xxxB (00H) Reserved for VMC
00001xxxB (08H) Changer
00010xxxB (10H) Cashless Device #1
00011xxxB (18H) Communications Gateway
00100xxxB (20H) Display
The B just stands for Binary on page 29. so it is not the hex value 11.
2.1 Byte Format
Tte protocol sends a byte with the address first and then a (POLL) command as a separate byte.
The Mode bit, which is bit 9(!),  defines if the byte is to be interpreted as an address or a command.
The MOde bit is also used to indicate EndOfPacket (Slave to Master)
Baud Rate: 9600 NRZ
Serial Bit Format:
1 Start Bit
8 Data Bits
1 Mode Bit
1 Stop Bit
11 Bits Total
Start 0 1 2 3 4 5 6 7 Mode Stop
Mode Bit: Master-to-Peripheral
The mode bit differentiates between ADDRESS bytes and DATA bytes. ADDRESS
bytes must be read by all peripherals, DATA bytes are only read by the peripheral that
has been addressed.
The mode bit is set (logic one) to indicate an ADDRESS byte, and not set (logic zero) to
indicate a DATA byte.
Mode Bit: Peripheral-to-Master
The mode bit must be set on the last byte sent when data is sent from a Slave to the
Master
This is NOT covered by the standard Arduino Serial communication, there are other libs that support 9 bits (search the forum).
To send the poll command you should send 2 bytes
0000 1xxx 1 (address of device + mode bit set)
0000 1101 0 (poll command + mode bit off)
paragrah 5.3 explains the responses of the device ....
Post by: streetHawk on May 05, 2012, 05:47 am
Thanks for your reply Robtillaart, I appreciate it. But i am again lost :(
---- pg 26 -----
The upper five bits (MSB) of the Address Byte will be used for addressing. That is, bits
7,6,5,4,3 of the previous byte description will be used for addressing.
The lower three bits (i.e. 2,1,0) of the Address Byte will contain peripheral specific
commands. This will allow up to eight instructions to be embedded in the first byte of a
block.
So Poll is a command and not a data; Does it mean poll command (0x0b) has to fit into this 3 bits ? how do i do it ?
Also in the section 2.5
VMC:
      ------- ADD*---- CHK-----------
Peripheral:
-------------------------------------ACK*------------
*Indicates mode bit set
This is a typical case when i need to send a poll command, there doesnt seem to be any data byte. so how do i send the poll command, please help im very confused here.
Hwk
Post by: robtillaart on May 05, 2012, 12:47 pm
It cannot as B = 1011 so it need 4 bytes. => conclusio => POLL should be send seperately ,
unfortunely I don't have such device to test :(
