Arduino Forum
Using Arduino => LEDs and Multiplexing => Topic started by: kculm on Jan 17, 2013, 01:48 am
Title: MegaBrite RGB
Post by: kculm on Jan 17, 2013, 01:48 am
Hi All,
I piceked up a Mega Brite RGB (Tiro) From Sparkfun.com
https://www.sparkfun.com/products/10236.
The thing is am very new to all this. (about a month) and I am not sure how to use it.
I looked at the example sketch and was able to figure out the PIN's some what. But when I Run it only the Blue and red come on.
Thanks of any help given .
#define clockpin 13 // CI
#define enablepin 10 // EI
#define latchpin 9 // LI
#define datapin 11 // DI
#define NumLEDs 2
int LEDChannels[NumLEDs][3] = {0};
int SB_CommandMode;
int SB_RedCommand;
int SB_GreenCommand;
int SB_BlueCommand;
   pinMode(datapin, OUTPUT);
   pinMode(latchpin, OUTPUT);
   pinMode(enablepin, OUTPUT);
   pinMode(clockpin, OUTPUT);
   SPCR = (1<<SPE)|(1<<MSTR)|(0<<SPR1)|(0<<SPR0);
   digitalWrite(latchpin, LOW);
   digitalWrite(enablepin, LOW);
void SB_SendPacket() {
    if (SB_CommandMode == B01) {
     SB_RedCommand = 120;
     SB_GreenCommand = 100;
     SB_BlueCommand = 100;
    SPDR = SB_CommandMode << 6 | SB_BlueCommand>>4;
    while(!(SPSR & (1<<SPIF)));
    SPDR = SB_BlueCommand<<4 | SB_RedCommand>>6;
    SPDR = SB_RedCommand << 2 | SB_GreenCommand>>8;
    SPDR = SB_GreenCommand;
void WriteLEDArray() {
    SB_CommandMode = B00; // Write to PWM control registers
    for (int h = 0;h<NumLEDs;h++) {
  SB_RedCommand = LEDChannels[h][0];
  SB_GreenCommand = LEDChannels[h][1];
  SB_BlueCommand = LEDChannels[h][2];
  SB_SendPacket();
    delayMicroseconds(15);
    digitalWrite(latchpin,HIGH); // latch data into registers
    digitalWrite(latchpin,LOW);
    SB_CommandMode = B01; // Write to current control registers
    for (int z = 0; z < NumLEDs; z++) SB_SendPacket();
   LEDChannels[0][0] = 1023;
   LEDChannels[0][1] = 0;
   LEDChannels[0][2] = 0;
   LEDChannels[1][0] = 0;
   LEDChannels[1][1] = 0;
   LEDChannels[1][2] = 1023;
   WriteLEDArray();
   delay(200);
   LEDChannels[0][0] = 0;
   LEDChannels[0][2] = 1023;
   LEDChannels[1][0] = 1023;
   LEDChannels[1][2] = 0;
   WriteLEDArray();
   delay(200);
Title: Re: MegaBrite RGB
Post by: kculm on Jan 17, 2013, 02:00 am
My Bad,
After reading more about the sketch in the supplied Doc. All it is supposed to do is blink Red and Blue.
That being said, Now I really need help.
Thanks once more.
Post by: JoeN on Jan 17, 2013, 05:58 am
What idiot designed the header angles on that board?
Post by: macegr on Jan 17, 2013, 08:43 am
Me. They're...fun!
Post by: JoeN on Jan 17, 2013, 02:41 pm
Me. They're...fun!
Then I take back the idiot part.  And they are fun and interesting.  But how doesn't that kill you for using it on a breadboard?  It has to make it harder to interface it even on a custom made PCB because it's harder to verify its right before sending it off to be manufactured too.  What is the point?
Post by: fungus on Jan 17, 2013, 04:13 pm
What is the point?
You can easily put six of them together in a circle to make a GigaBrite..?
Post by: Hippynerd on Jan 17, 2013, 06:02 pm
I really like the hexagonal shape, it tessellates quite nicely, you can make a honeycomb pattern. There are some interesting 3D polygons that you could make with a hexagon. Pentagonal would be real nice for 3D geometric shapes also.
Post by: fungus on Jan 17, 2013, 06:07 pm
I don't think you'd want to put both sets of pins in a breadboard anyway. One set of pins is just for daisychaining.
Post by: kculm on Jan 17, 2013, 06:37 pm
Me. They're...fun!
I have a Favor, because I am new to all this and I got a lot to learn. Any way you could post or PM me some more Example code. Or explain in a dumbed down version on the code that is in the Doc.
I got some of it figured out. I can make all three LED's blink on and off and dim. But thats all.
Thanks
Post by: JoeN on Jan 17, 2013, 07:09 pm
What is the point?
Buying enough for a gigabrite would get pricy... :)
Post by: Hippynerd on Jan 17, 2013, 07:22 pm
It takes 10 kilobucks to make one gigabright.
edit:
Actually, i guess thats 9.95 Kbucks.
Doh, looks more like 7.96 Kbucks if you get 100 pricing...
4th edit:
2^10, seems appropriate...
Post by: JoeN on Jan 17, 2013, 07:24 pm
edit:
It sounds like you are using 10^3 as your definition of kilo.  It may be 2^10 in this case, but I am not sure.   ]:D
Post by: fungus on Jan 17, 2013, 07:48 pm
I can imagine a big LED snowflake made with those. You couldn't do that with square ones. :)
Post by: Hippynerd on Jan 17, 2013, 08:08 pm
Snowflakes make matrices look like squares.
Post by: macegr on Jan 18, 2013, 12:09 am
The plan was to use them with cables and mount them on objects, rather than plug them into a breadboard or solder them into a PCB. Therefore the angled headers seemed less of a problem. We never did a redesign, but making the headers parallel was definitely on the to-do list.
Post by: fungus on Jan 18, 2013, 02:16 pm
I think the hexagon is better for the sort of things I can imagine doing with them, eg. Arranging them in patterns on walls/ceilings, putting them inside circular light fittings, attaching them to other stuff.
(Trying to connect several of them together on a breadboard isn't anywhere on my list)
