Arduino Forum
Using Arduino => Programming Questions => Topic started by: American2020 on Mar 23, 2013, 04:36 pm
Title: Extend Flash Memory
Post by: American2020 on Mar 23, 2013, 04:36 pm
Hello. I'm new to this forum, and to this Arduino World.
I'm really happy with my Arduino Nano with Atmega 328
But, what I first notice is that the 32Kb I have available for the code, isn't good at all. I can't believe that been in the 21 Century we don't have like 1 Gb available (dunno why this limitation)
My question is. Is there anyway to  increase the memory for the code? I know Arduino can read SD Cards, is it possible to put the code in the SD card and run the code from there? or a PenDrive, I dunno...
Same question but for the SRAM and EEPROM both looks like with a big code (or not so big really) both of them will collapse.
Thanks a lot, hope you can clarify my panorama.
Title: Re: Extend Flash Memory
Post by: majenko on Mar 23, 2013, 04:53 pm
Cost.  If you want more, you buy a bigger, more expensive chip.  If you don't, you buy a cheaper chip with less.
No.
You can add EEPROM and SRAM as SPI or I²C peripherals - but you can't use the SRAM as if it were internal memory, but you have to manually reference addresses within it.
Post by: American2020 on Mar 23, 2013, 06:25 pm
Thanks Majenko.
Is the bigger one the Arduino Mega with only 256 Kb? Or is something bigger out there?
Anyway 256 I think would be much better than the 32Kb on the Nano, so it would be a good alternative and give us much more options when coding.
Anyway, in an era where everything is on Gb I don't understand why we are counting with Kb  :smiley-roll:
Thanks again Majenko  :)
Post by: majenko on Mar 23, 2013, 06:44 pm
Thanks Majenko.
Yes, the mega2560 has 256kB of flash.  The DUE has 512kB.
Your computer may count in gigabytes, but an Arduino isn't a computer.  It's a microcontroller.  It does a different job.  When people need a computer, they use a computer.   When they only need something small that will do a small job, they don't use a computer - they use a microcontroller.  It is small, it has small resources, and it has a small price tag.
If you want bigger, you buy bigger.  You don't use a sledgehammer to crack a nut just because sledgehammers are the biggest things around.  You use the tool that is right for the job.  Similarly, you don't use a ball peen hammer to demolish a building.
Post by: American2020 on Mar 23, 2013, 07:09 pm
:D
Lol that's true :)
My next step for sure then, it will be the Mega or the Due. With a friend we are going to turn an Arduino to be the "brain" of a Pinball :P
Hopefully we will get it working as we want.
