Arduino Forum
Using Arduino => Installation & Troubleshooting => Topic started by: bernieaw on Apr 19, 2013, 01:44 pm
Title: 2560 slow compiling
Post by: bernieaw on Apr 19, 2013, 01:44 pm
This is the sketch I am running.  It takes about a minute to compile, then it fails to upload. It will eventually upload after about 4 attempts.
int LED = 13;
  pinMode(LED,OUTPUT);
  digitalWrite(LED,HIGH);
  delay(100);
  digitalWrite(LED,LOW);
Title: Re: 2560 slow compiling
Post by: hugo007 on Apr 19, 2013, 04:06 pm
If you are using windows did you already tried to stop the anti virus protection?
When I use Windows I need to shutdown the Kaspersky because it cause a very slow compile.It's because it have a true Prevent feature that monitor all activity.
Of course it could be another problem ...
Post by: bernieaw on Apr 19, 2013, 06:54 pm
Hi Thanks for your reply.
I disabled all my antivirus and firewall settings, and it compiled ok for a few minutes then went back to running very slowly again. I'm very puzzled!!???
Post by: eried on Apr 19, 2013, 07:37 pm
Several people report this issue time to time. If you set TeamViewer in your machine and send me the ID and pass via private message I can try to solve your problem and discover the root.
Post by: eried on Apr 19, 2013, 10:23 pm
OK it was some security solution interfering after all. Hey bernieaw can you post the picture I left for you? I didn't saved it. But it will be useful for other guys with the same problem.
Title: Re: 2560 slow compiling - fixed for me Kaspersky -
Post by: rholt on Jun 18, 2014, 09:03 pm
 :0 bringing down Kaspersky made the difference for me. worked fine @ home but not here @ work where we have Kaspersky Running.
for HugoPT - sometimes when u shut down an AV, it will only shut down for a specified number of minutes and then turn the AV back on again... this is for safety. I will see if there's a workaround in order to allow this program to run uninhibited.
Russ from Coral Springs, Fl  8)
