Arduino Forum
Using Arduino => Microcontrollers => Topic started by: Arduino14 on Jun 04, 2016, 11:05 am
Title: Receive ir signal with attiny13
Post by: Arduino14 on Jun 04, 2016, 11:05 am
I, after had seen that is possible use a 433mhz transmitter with this little avr, I would to use it in order to receive ir signal from a remote and then, for example, light a led. Googling a bit I've seen many Russian people that have done this but in assembler. I'd like to compile it using the arduino ide. Does someone tried this?
Title: Re: Receive ir signal with attiny13
Post by: couka on Jun 04, 2016, 01:11 pm
Second result when asking google for "attiny13 ir receiver arduino":
https://www.google.de/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwjUubSLno7NAhUKlxQKHcGIC98QFggkMAE&url=http%3A%2F%2Fwww.instructables.com%2Fid%2FThe-Easiest-Way-to-Use-Any-IR-Remote-with-Ardiuno%2F&usg=AFQjCNFbfyO55_tmDNhUlJ3qlrk7F6rjfg&sig2=ReNNpvGTJhP_3QFrVhy5BQ&bvm=bv.123664746,d.bGg (https://www.google.de/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwjUubSLno7NAhUKlxQKHcGIC98QFggkMAE&url=http%3A%2F%2Fwww.instructables.com%2Fid%2FThe-Easiest-Way-to-Use-Any-IR-Remote-with-Ardiuno%2F&usg=AFQjCNFbfyO55_tmDNhUlJ3qlrk7F6rjfg&sig2=ReNNpvGTJhP_3QFrVhy5BQ&bvm=bv.123664746,d.bGg)
lg, couka
Post by: Arduino14 on Jun 04, 2016, 01:55 pm
You're wrong, this is for use the receiver with arduino, not attiny!
Post by: mrburnette on Jun 04, 2016, 02:41 pm
... I would to use it in order to receive ir signal from a remote and then, for example, light a led. ...
It is very easy on a tiny85, I have not worked with the tiny13.
IR on a Tiny85 (http://www.hackster.io/rayburne/infrared-dedicated-decoder)
Ray (https://www.hackster.io/rayburne/projects)
Post by: Arduino14 on Jun 04, 2016, 03:06 pm
The code is incompatible with the tiny13 because different frequency
