Arduino Forum
Using Arduino => Sensors => Topic started by: teutek213 on Dec 07, 2017, 09:11 pm
Title: MPX5700GP pressure sensor
Post by: teutek213 on Dec 07, 2017, 09:11 pm
Hello,
i have problem with my gauge pressure sensor
i found  2 different topics with MPX5700GP
https://forum.arduino.cc/index.php?topic=425830.0 (https://forum.arduino.cc/index.php?topic=425830.0)
https://forum.arduino.cc/index.php?topic=99381.0 (https://forum.arduino.cc/index.php?topic=99381.0)
an they still didnt solve my problems
maybe sth is with my sensor maybe with code or arduino idk :/
im using arduino nano with lcd and LCM1602
there is my code
#include <Wire.h>
#define BACKLIGHT_PIN 3
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7);
  lcd.begin(16, 2);
  lcd.setBacklightPin(BACKLIGHT_PIN, POSITIVE);
  lcd.setBacklight(HIGH);
  lcd.home();
  lcd.print("Voltage");
  lcd.setCursor (0, 1);
  lcd.print("Pressure");
// averaging for noise removal
  float sensorValue = analogRead(A0);
  float voltage = 5000.0 * sensorValue * (1.0/1024.0);  // mV
  float pressure = ((((voltage / 5) - 0.04) / 0.0012858)/1000.0) ;  // kPa
  lcd.setCursor (10,0);
  lcd.print(voltage);
  lcd.setCursor (10,1);
  lcd.print(pressure);
in attachments there is data sheet for this sensor
after vcc connection on display
i can see
voltage  258.79 (in mV)
and pressure 40.22 (and this in kPa)
this valuse sometimes are softly lower or higher but those are slight changes
so for me it is big offset of valid value
thank you in advance for any help  ;)  ;)
Title: Re: MPX5700GP pressure sensor
Post by: Wawa on Dec 07, 2017, 11:15 pm
Not a good idea to see a pressure sensor as a voltmeter.
Your code assumes a 5.000volt supply, but a Nano on USB power is more like 4.6volt.
Sensors like this are ratiometric, and you should convert directly from A/D value to pressure.
Try this example.
I already calculated the offset and span for this MPX5700, but it might need finetuning.
Don't expect that a pressure sensor and 10-bit A/D (1024 values) can display 700 with two decimal places precision.
Leo..
// MPX5700 pressure sensor (700kPa)
int rawValue; // A/D readings
int offset = 41; // zero pressure adjust
int fullScale = 963; // max pressure (span) adjust
float pressure; // final pressure
  rawValue = analogRead(A0);
  pressure = (rawValue - offset) * 700.0 / (fullScale - offset); // pressure conversion
  Serial.print("Raw A/D is  ");
  Serial.print(rawValue);
  Serial.print("   Pressure is  ");
  Serial.print(pressure, 1); // one decimal places
  Serial.println("  kPa");
Or, with a bit of averaging for a more stable readout and better offset adjustment.
int offset = 410; // zero pressure adjust
int fullScale = 9630; // max pressure (span) adjust
  rawValue = 0;
  for (int x = 0; x < 10; x++) rawValue = rawValue + analogRead(A0);
Post by: teutek213 on Dec 13, 2017, 07:20 pm
Hi Leo,
i used your second code and there is a little better read because i get :
Raw A/D is  573   Pressure is  12.4  kPa
Raw A/D is  576   Pressure is  12.6  kPa
Raw A/D is  575   Pressure is  12.5  kPa
this value still didnt content me :/
but i dont have more ideas :(
thank you for help
maybe now with this readings you can help more
Post by: teutek213 on Dec 13, 2017, 07:37 pm
I found
page with other MPX5100gp which pressure range is 100kPa
and scale is from 0.2 to 4.7 V the same like mine sensor
https://circuits4you.com/2016/05/13/arduino-pressure-measurement/
i used their code
  Air Pressure Measurement usning MPX5010 or MPX5100 Pressure Sensor
  www.circuits4you.com
const float SensorOffset = 102.4;
// the setup routine runs once when you press reset:
  // initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
  // read the input on analog pin 0:
  float sensorValue = (analogRead(A0)-SensorOffset)/700.0; //Do maths for calibration
  // print out the value you read:
  Serial.print("Analog Read ");
  Serial.print(analogRead(A0));
  Serial.print('\n');
  Serial.print("Air Pressure: ");
  Serial.print(sensorValue,1);
  delay(1000);        // delay in between reads for stability
and i get
Analog Read 63
Air Pressure: -0.1 kPa
Analog Read 63
thats are better readings but id dont know that this is valid code
thank for your help
Mateusz
Post by: Wawa on Dec 13, 2017, 07:57 pm
Edit: Stop using other sketches. The second sketch in post#1 works perfectly after calibrating.
Are these values without any pressure on the sensor?
Did you read the comments of the sketch?
You need to adjust some of the values for YOUR sensor/setup.
1) remove the hoses from the sensor, and change the offset value (and re-upload the sketch) until the serial monitor is as close to zero as possible. This is the "410" value if you use the second (better) sketch.
Do it in small steps, e.g. 400 or 395, or 420 or 425.
2) You can skip this part, but if you have the means of calibrating the sensor then:
Connect the hoses again, and put a known pressure on the sensor.
Adjust the max pressure(span) value (and re-upload every time), until the value on the serial monitor shows the same value as the known pressure.
Leo..
Post by: outsider on Dec 13, 2017, 08:10 pm
Leo, in your second sketch, did you forget:
rawValue /= 10;
Never mind. :-[   I'm in training for the blunder olympics.
Post by: Wawa on Dec 13, 2017, 08:34 pm
Haha. Be prepaired for some fierce competition. I'm also joining.
Leo..
Post by: teutek213 on Dec 13, 2017, 09:13 pm
Hi Leo
i used arduino uno as 5v power supply and it works quite good
i get:
Raw A/D is  420   Pressure is  0.8  kPa
Raw A/D is  418   Pressure is  0.6  kPa
for me sounds perfect <3
thank you a lot
  rawValue = 0;
code for future searcher :)
Mateusz
