Arduino Forum
Using Arduino => General Electronics => Topic started by: Cylindric on Jul 06, 2011, 01:08 pm
Title: Tricks of the trade - Connecting projects to the Arduino boards 'reusably'
Post by: Cylindric on Jul 06, 2011, 01:08 pm
Hello hello,
I was wondering what sort of insider "tricks of the trade" some of you might have.
Particularly right now, I'm working on two (my first two ;)) projects, and would rather not buy a second Uno, but was curious as to what methods you might be using to quickly connect and disconnect a semi-permanent breadboard mess of experimental components to an Arduino.
I was thinking of just having multiple small (or large) breadboards that bring all their pin and power leads to a single pin-header, then I can simply connect and disconnect a board without too much stress.
What sort of connectors?  I'm not thinking Mega here with dozens of pins, there will probably only be in the order of 8-16 pins to deal with.
What are the black connectors called like used on the Arduino board, and the bottom of Shields?  I think they might be cool if I can fix the wires into them.
Title: Re: Tricks of the trade - Connecting projects to the Arduino boards 'reusably'
Post by: Grumpy_Mike on Jul 06, 2011, 03:10 pm
0.1" single row header pins.
I just use them, there are some photos of this on this project:-
http://www.thebox.myzen.co.uk/Hardware/Crazy_People.html (http://www.thebox.myzen.co.uk/Hardware/Crazy_People.html)
Post by: Cylindric on Jul 06, 2011, 03:13 pm
Cool - I'll pick up some of those and have a go.
Post by: justjed on Jul 07, 2011, 01:23 am
Would this work? http://liudr.wordpress.com/gadget/phi-connect/
Post by: Bobnova on Jul 07, 2011, 03:55 am
The easy way is to use a Bare Bones Board, Really Bare Bones Board, or Boarduino type clone, they plug into the breadboard directly.
The Bare Bones Board is my favorite, moderndevice.com sells 'em.
Post by: roypogi on Jul 07, 2011, 06:26 am
My vote also goes to the boarduino from Adafruit. You can also build your own so you can tailor it to all your needs. About a year ago I did something like this(attached) with all the pins coming off on one side in a single line. Easy to use and consumes very little breadboard space. I have since modified its power supply and a smaller board.
Post by: CrossRoads on Jul 07, 2011, 06:57 am
What's connected at the circled area near A1? Is that for a resonator?
Post by: roypogi on Jul 07, 2011, 07:26 am
Yes, I have since replaced it with an SMD part as it sticks out a little bit.
Post by: CrossRoads on Jul 07, 2011, 07:42 am
Did you make it easy to connect something like an FTDI Basic for easy downloading? Or does one just connect to the appropriate pins once plugged in the breadboard using flying leads off the USB/RS232 adapter?
Post by: roypogi on Jul 07, 2011, 07:56 am
I have always used the ICSP for my projects but I guess if needed a 6 pin header can be placed on the board(or as you suggested using the breadboard). I actually gave it a name when I designed it. SAduino, short for Side Action Arduino. :-)
I'll look for the redesigned board files for those whore are interested, but the design is basic and straight forward.
Post by: CrossRoads on Jul 07, 2011, 10:47 am
I had a little fun mimicking a Side-uino design using Duemilanove kind of parts, and watch Eagle go thru its paces laying it out.
Maybe will help it out a little tomorrow and neaten it up some.
(http://www.crossroadsfencing.com/Side-uino.jpg)
Post by: roypogi on Jul 07, 2011, 06:03 pm
Nice!
Maybe we could spin this off as a community designed yet another arduino clone. I know the form factor works well because of its thin breadboard foot print
Post by: CrossRoads on Jul 08, 2011, 01:44 am
I want to take a shot at putting the DIP part in there, give folks a chance to recover when they damage the 328.
Think I just need to move the big cap down under the regulator to make room.
Post by: retrolefty on Jul 08, 2011, 01:56 am
Long live the DIP package. Oh and leave room for socket mounting the 328 8)
Post by: CrossRoads on Jul 08, 2011, 01:58 am
That's what I was thinking.
Post by: roypogi on Jul 08, 2011, 09:07 am
DIP sounds good since this will probably see burned chips here and there.
We could use a ceramic chip for the caps 22uf/25v(1210) x2 , I have a ton of those and they are pretty cheap. Lets give it a shot and compare notes.
Post by: CrossRoads on Jul 08, 2011, 09:40 am
Ok, I've got a DIP version all layed out with just a single via, ICSP, and FTDI connector.  Run from Vin thru unfused 5v regulator, or bypass regulator with +5v directly.
Any thoughts?
Needs some board labeling work still.
(http://www.crossroadsfencing.com/Side-uino_DIP.jpg)
Post by: CrossRoads on Jul 08, 2011, 09:48 am
"ceramic chip for the caps 22uf/25v(1210) x2 "
Send the eagle reference for that, should be easy to add in.
100uF on regulator output does seem a little overkill here.
Post by: Cylindric on Jul 08, 2011, 10:27 am
Well I was just expecting "lol - use wires", but this'll do too :D
Post by: Bobnova on Jul 08, 2011, 05:39 pm
Not to rain on anybodies parade, but that's what the BBB is:
(http://cdn.shopify.com/s/files/1/0038/9582/products/BBB_Assembled_1_grande.jpg?100094)
It has a FTDI connector too, and a pair of pins that go down into the power rail so you don't have to jumper power into it.
Post by: liuzengqiang on Jul 09, 2011, 10:51 pm
Thanks for mentioning my design  :)
If you need to move between two projects you can use 1 or even just 2 RBBB but you can't use any shield with RBBB. Plugging it and unplugging it is a bit hard (too many pins) on my larger breadboards but is ok on the tiny breadboards I used. They're all kind of loose. If you need to use shields with prototyping, the phi-connect is better. The arduino clones such as BBB or RBBB are designed to support pure breadboard prototyping without shields.
