Arduino Forum
Using Arduino => General Electronics => Topic started by: srusha on Oct 10, 2012, 03:36 pm
Title: DG408 wiring
Post by: srusha on Oct 10, 2012, 03:36 pm
Hello, I have DG408 (http://datasheets.maximintegrated.com/en/ds/DG408-DG409.pdf)
and it says in the following scheme that there is V+, V- and gnd, what does V- stands for?
(http://www.dzsc.com/icstock/uploadfile/200913174131315.jpg)
thanks in advance,
Title: Re: DG408 wiring
Post by: silasmoeckel on Oct 10, 2012, 05:07 pm
thanks in advance,
Just what it says negative supply voltage.  That chip normally runs with 15v +- but supports a lot of different configurations. If you want to use it with positive voltage only connect v- to gnd as the datasheet says on page 6.
Post by: CrossRoads on Oct 10, 2012, 05:13 pm
If you were running from dual supply, like +12V/-12V, V- would be -12V.
If running from single +5 supply, V- goes to Gnd, per page 4.
Post by: srusha on Oct 11, 2012, 09:39 am
Thats what I thought,
thanks for the quick reply.
