Arduino Forum
Using Arduino => Project Guidance => Topic started by: renasis on Mar 25, 2012, 09:26 pm
Title: Set Arduino serial baud rate above 115200 ->230400, 256000,307200,614400
Post by: renasis on Mar 25, 2012, 09:26 pm
Hello,
I would like to increase the speed of the serial port above 115200 baud. I have tried the test below. Usb cable from pc connected to arduino 328p. Tried to view results in br@y terminal 1.9b. It did not print anything(if I try same test with 115200, it works fine). Do I have to modify hardwareserial.cpp in order to achieve these higher speeds?
Thanks,
-ren
  Serial.begin(256000);
  Serial.println("Hello world!");
Title: Re: Set Arduino serial baud rate above 115200 ->230400, 256000,307200,614400
Post by: robtillaart on Mar 25, 2012, 10:42 pm
you have to use tuned speeds that fit nicely with the 16MHz clock.
got succesfull transfers at 230400, 345600 and 500000
see older thread - http://arduino.cc/forum/index.php/topic,61381.msg444421.html#msg444421
Post by: Coding Badly on Mar 25, 2012, 11:05 pm
I typically use 250K and have had no problems.
Post by: renasis on Mar 26, 2012, 12:07 am
robtillaart,
Yes, I see that now.  I did get 230400 to work, had data bits set incorrectly to 7 in the terminal. If I keep the speeds listed on the mega 328 datasheet for 16mhz, it works well, as you stated. I tried pushing it to 2mbs using the code you posted(see below). I didn't do any error checking, but it seemed to work fine. By the way, if anybody is interested, the speeds listed in the datasheet for 16mhz are 230400/250000/500000/1000000. Also it doesn't have it listed, but indicates 0% error up to 2mbs using u2xn=1.
Thanks for the help!
-ren
 Serial.begin(2000000);   // !! 115200, 230400, 345600,   460800 X
 //delay(1000);
 //Serial.println("Hello World");
 unsigned long t1 = millis();
 for (long i=0; i< 10000; i++)
  Serial.println("12345678");  // 10 bytes incl \r\n
 Serial.println(millis() - t1);
Post by: liuzengqiang on Mar 26, 2012, 12:35 am
I'm interested in this topic as well. Can I ask all that asked/replied what USB/TTL adapter you are using? I have FTDI and 8u2 with arduinos and a moderndevice.com usb bub II.
Post by: Coding Badly on Mar 26, 2012, 03:07 am
Arduino Uno.  Pololu USB AVR Programmer.
Post by: robtillaart on Mar 26, 2012, 06:52 am
uno & 2009, std usb
Post by: renasis on Mar 27, 2012, 01:48 am
arduino duemilanove std usb cable
Post by: GoForSmoke on Mar 27, 2012, 02:49 am
How does this compare to SPI?
One reason is that every mobo I have owned for over 10 years now has SPI.
Post by: liuzengqiang on Mar 27, 2012, 02:53 am
Thanks for the good news. I'll try this also. It's (500000) a lot better than 115200 with almost 8% error because of frequency mismatch.
Post by: Coding Badly on Mar 30, 2012, 07:10 am
SPI requires two lines (but usually uses three or four) instead of the one (but usually uses two) required for serial connections.  Clocking is always performed by the master; neither the master nor the slave needs a calibrated clock.  Serial requires both sides to have moderately calibrated clocks.  The maximum bitrate of SPI is F_CPU / 2 (8 Mb/s).  For asynchronous serial communications the maximum bitrate is F_CPU / 8 (2 Mb/s).
I wonder if that could be used for programming.
Post by: GoForSmoke on Mar 30, 2012, 10:52 am
It seems that they are there to at least recover bricked bios'es.
I also see some articles on Linux SPI drivers but wow, not simple!
