Topic: I2C between 8MHZ & 16 MHz arduinos (Read 2403 times) previous topic - next topic
magnethead794
Sep 01, 2012, 04:47 am Last Edit: Sep 01, 2012, 04:54 am by magnethead794 Reason: 1
Any issues with doing it? Just wondering. Need to link a FIO and a mega over I2C.
Yes I know level conversion will be needed.
(the other end of the xBee link is a FIO & teensy2.0++ pairing..same deal there)
frank26080115
there shouldn't be any issues
level conversion will not be needed, just disable internal pull-up resistors and use external pull-up resistors that "pull" to 3.3V
magnethead794
So the 5V signals coming from the 5V board won't overdrive the 3V3 pins?
cmiyc
That's why you use external pull-up resistors.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
magnethead794
Doesn't make sense to me, but I'll go with it.
cmiyc
Research "open collector".
The I2C pins are open-collector.  They need to be pulled-up so if you external resistors and pull them up to 3.3V they become 3.3V pins.
magnethead794
works for me.
