Topic: DIP Solder header still in use? (Read 3975 times) previous topic - next topic
louarnold
Some years ago, prototypes (after breadboard trials) were built with IC sockets for both ICs and for components. Components were soldered to component carriers - into small Y forks. The carriers were then inserted into the DIP sockets. That saved space and made things flexible. However, I don't see many such solder headers available except at rather high prices from US distributors. None come from China at a much cheaper rate. Is a cheaper, more suitable alternative being used these days?
runaway_pancake
Those things seemed like they'd be more useful than they actually were.
There were even a kind that had a little box to go over the DIP platform.
But the plastic used was always pretty sucky, couldn't stand the slightest suggestion of heat.
I fab modules with experimenter board, plated-thru holes or the strip-board kind, and solder SIP rail/s for plugability.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
oric_dan
#2
Nov 18, 2012, 03:16 am Last Edit: Nov 18, 2012, 03:17 am by oric_dan(333) Reason: 1
http://www.jameco.com/1/3/dip-header
But like R_P says, probably less useful than thought ahead of time, and not especially
cheap, but I imagine the jameco prices are about what to expect.
louarnold
I fab modules ...solder SIP rail/s for plugability.
I didn't understand that comment. I have a "PC Breadboard" (a plated board that has the size and layout out much like a solderless type). Where do you put the SIP rails - where the DIP pins would go? See the attached image.
louarnold
Edit: These seem pretty cheap and they look like the good ones I bought years ago.
http://eolsurplus.com/Components.html
search for component carrier.
I did look at the web page. I sent an email to see what the shipping charge is. $10 for 45 pieces is good. We'll see.
runaway_pancake
I get out my Dremel and cut out small sections from
experimenter board and go from there.
In this pic, I made a plug / cable lead-out, but I could have jammed
some components on it same way (without the leads), same principle:
Those fibreglas carriers look nice, I remember seeing one a long time ago.
Maybe they were all that way at first and someone said, "Hey, let's use crappy low-temp plastic instead."  (:
louarnold
#6
Nov 18, 2012, 06:33 pm Last Edit: Nov 18, 2012, 06:34 pm by louarnold Reason: 1
To R_P: Now I understand what you meant. But I was talking about something different. If you saw the headers, then you know.
But thanks for your efforts anyway.
retrolefty
#7
Nov 18, 2012, 06:43 pm Last Edit: Nov 18, 2012, 06:45 pm by retrolefty Reason: 1
I believe the OP is taking about this style: http://www.goldmine-elec-products.com/prodinfo.asp?number=G18635
They also carry a 8 pin version.
http://www.goldmine-elec-products.com/prodinfo.asp?number=G18626
Lefty
jwax
I'm new to the forum, and hope I'm not hijacking this thread, but have a relevant question:
If I want to solder wires directly to the Arduino Uno permanently, how do I remove the headers?
Hot air desoldering tool?
Thanks!
John
retrolefty
Thanks!
John
Really not worth the time consumption and risk to board damage in my opinion. Just buy some male header pin strips, break off the number of pins you wish to use. Solder your wires to the short pins of the header pins and insert the long pins into the shield header socket(s). These make very secure connections and if you use proper sized stranded wire should hold up well. Some people like to add glue (epoxy or hot glue) to the wire/short pin side of your newly made connector to add a little strength and strain relief to the solder joint.
https://www.sparkfun.com/products/116?
Lefty
fungus
If you've got one, yes. If not I'd just break them up a bit with a pair of cutters then desolder the pins.
OTOH you could buy one of these and save some time/money: http://evilmadscience.com/productsmenu/tinykitlist/180
louarnold
No reply to my email after 3 days. No pint in pursuing this.
louarnold
That's the trouble with online stuff; you never know if it's been posted for a week, a month, a year...
Hope you find what you're looking for.
Well, that's the point. If these carriers are no longer in common use, then people have already found a better alternative.
Perhaps single row female headers will be better. But that would mean inserting resistor (etc) leands into the header instead of soldering them. But its a very flexible approach. You could change values and locations without soldering at all. The next step would be a custom PCB.
