Topic: Create a spark or burning coil with Arduino (Read 12796 times) previous topic - next topic
encryptor
Dec 06, 2012, 11:57 pm Last Edit: Dec 07, 2012, 12:02 am by encryptor Reason: 1
How would I create a spark with the arduino?  Can you hack a grill ignitor or model rocket launch controller?  I'm thinking to recreate the Zeppelin blimp, but with flame retardant paper shell.  I was thinking to fill with hydrogen by a foil and hydrochloric acid  mix leading up to the blimp interior.
Then either by a timed delay or RC control cause an internal combustion inside the blimp to see what the end result would be.  what if the design works, proven a new shell material could bring back the hydrogen blimp! Can I break a small light bulb and burn the tungsten coil thru a digital pin?  :P
http://www.hobbylinc.com/Model_Rocket_Launch_Controller
billroy
SparkFun, perhaps not surprisingly, sells sparks: https://www.sparkfun.com/products/11218
-br
encryptor
Nice, that rocks!  It looks dangerous if it pulls 3 amps
billroy
It does sound quite impressive.  Not for direct connection to an arduino pin, at that level of current.  Search the forum and read up on driving high-current peripherals with a transistor or FET, or even a relay, which itself will require a transistor.
-br
retrolefty
And of course also a DC power source capable of 3 amps or more. I want one but I don't yet know it I want one for $15.  :D
Lefty
keeper63@cox.net
If you do this, don't fill it with hydrogen in this manner. And please don't light it off. Why?
Because what you are describing is basically a kind of poisonous gas bomb; the reaction of hydrochloric acid with aluminium basically creates hydrogen and chlorine gas via an exothermic reaction (that is, the reaction gets hot - very hot). In fact, left to its own devices, with enough aluminium and a high enough concentration of HCl, it will self-ignite. It's actually a commonly known "anarchist's cookbook" type of device (though usually done in a capped-off 2 liter bottle, with a burning candle or flare on top - nothing like burning plastic shrapnel and chlorine gas to get your blood going!).
Likely, you wouldn't poison yourself, but you might make yourself sick, eye irritation (or worse), etc - such a mix is very nasty stuff...
Well - if all you had inside the gas envelope was hydrogen - absolutely nothing would happen, because you need oxygen mixed in the right amount in order for it to combust...
jabbado
I agree. Although we used to fill 75 liter garbage bags using a slightly different (but just as dangerous) reaction. Everything was weighed accurately and cold water baths used to control the reaction rate. But I studied chemistry so was aware of the dangers, and what was the quickest way to the shower, and to the hospital. Still a silly thing to do.
BTW, hydrogen will ignite over a huge range of O2 concentrations. Even a few percent of oxygen could likely turn your blimp into a bomb.
encryptor
#7
Dec 07, 2012, 04:54 pm Last Edit: Dec 07, 2012, 10:11 pm by encryptor Reason: 1
oh shit that does sound dangerous just mixing the 2 items aluminum and hydrocloric acid.  I've once did it ouside in a glass flash.  I'm not sure if it was enough to inflate a balloon completely.  I won't do that, however a gas filled blimp that exploded would be cool caught on video!  the dangerous by-produce of chlorine gas I wouldn't worry about too much because the experiment would be outside and we would be plenty aware of the gas.  At a higher height no one should be affected. :*
do you guys think Spark Gap ignitor create a spark hot enough to lite a medium sized bottle rocket or even a model rocket engine???  How cool would it be to have a model airplane that could shoot bottle rockets by IR control!  ^_^
graynomad
I used to use small light bulbs (6 or 12v) with the glass broken/removed to set various things off. The filament gets red or even white hot then burns out. Not a spark but may be good enough.
______
Rob
encryptor
Osgeld
model rocket electric matches, or 100VDC and 20 amps will make a large spark and a smoldering pile where your AVR once lived
focalist
#12
Dec 11, 2012, 04:48 pm Last Edit: Dec 11, 2012, 05:10 pm by focalist Reason: 1
Electrolysis of water is a MUCH safer method to produce hydrogen.. and oxygen for that matter.  Capture off the electrodes, and you can harvest nearly pure gases.  Best of all, you know you have a proper mix of hydrogen and oxygen, as your source and endpoints- water- are the same.  Energy stored in the chemical bonds is everything else..  In addition, it's pretty impressive once you think about it.  It will take quite a while to generate a good volume of gases.. depending on setup, hours or even days.  All the energy being dumped in to break the water chemical bonds over all that time... and when ignited, all that energy is released in a fraction of a second.  Electrolysis and combustion is a great hands-on example for demonstrating chemical storage of energy!
That all being said, I think you need to read a few things:
"The flammability limits based on the volume percent of hydrogen in air at 14.7 psia (1 atm, 101 kPa) are 4.0 and 75.0. The flammability limits based on the volume percent of hydrogen in oxygen at 14.7 psia (1 atm, 101 kPa) are 4.0 and 94.0."
"The limits of detonability of hydrogen in air are 18.3 to 59 percent by volume"[4]
http://en.wikipedia.org/wiki/Hydrogen_safety
Don't underestimate the power of the explosive you are dealing with.  This is NOT a safe project-- take EXTREME care... and if you have any doubts at ALL, do not do it.  You are essentially building a bomb if you try to contain detonating fuel/air vapor.  Even if explosion is avoided, the flame jet (which is invisible) will ignite ANYTHING it's close to- it will be a high-powered, invisible blowtorch (gas-fueled rocket?).  In either case, very dangerous.
retrolefty
Ah, but much more dramatic demonstrations of storage and release of energy can be had playing with strong nuclear forces rather then your wimpy chemical bonds.  ]:)
Lefty
focalist
#14
Dec 11, 2012, 05:15 pm Last Edit: Dec 11, 2012, 05:23 pm by focalist Reason: 1
My plan is to create a device which creates a galactic-scale black hole centered on me, which will go off the moment I die.  I may even opt for a full blown Gnab gib.
I'm taking it ALL with me.  Whoever said you can't obviously hasn't understood my plans, which include laser sharks and a domed island from which I will rule with an iron fist.
