Topic: Solution for the 5V vs 3.3V problem (Read 34993 times) previous topic - next topic
OsuDan
Hey Rob,
Here is what I'm thinking. This first drawing is a rough schematic for just the crosspoint section of pins. Other pins could be added to these and all the rest of the pins would need to be passed through 74LVC16245's as well.
Red trace is on bottom
Blue is on top
Black is on bottom (5v, 3.3v, gnd)
To answer you question about the pins, Mayhew Labs came up with a pretty nice solution.
http://dl.dropbox.com/u/55783756/Photos/go_between_shield_front%20(1).jpg
http://dl.dropbox.com/u/55783756/Photos/go_between_shield_back%20(1).jpg
As you can see, the headers don't go through the pcb, but are instead surface mounted. This way, we could have separate top and bottom circuits.
Dan
CrossRoads
Here's the schematic & layout, please create a version with the parts you are suggesting.
Top & bottom mount surface mount headers would be one way to keep the physical board the same size, as long as its cut back from the USB header.
graynomad
@OsuDan
At this stage a simple block diagram would be clearer, too many parallel lines for me to follow there.
_____
Rob
graynomad
This is one way I see it working,
It would need the above for every 8 pins you wanted to handle, but if you stick to the standard shield (not Mega) that's only 3x the above I think.
Bear in mind that some control circuitry would be required as well.
XPS = crosspoint switch
BUF = buffer, probably TXB0108
______
Rob
GorillaBuilderz
Also take a look at our http://playground.arduino.cc/GorillaBuilderz/LeoShield which is another pin adaptor.
Dale
www.GorillaBuilderz.com
Hey guys,
I've been looking into something like this for a while as well. One thing that caught my eye was this pin converter shield for the UNO/Leo to go between the old pinout and 1.0
http://mayhewlabs.com/products/go-between-shield
Something like this could be implemented with logic converters between the connection points. This could also leads in some other interesting directions as well:
  • Being able to select/designate individual pins as 5v or 3.3v logic
  • Integrating dynamic pin assignment so the pinout could be adaptable to older shields configurations
  • And if you really wanted to get crazy, you could even wire the whole thing up to be driven by an integrated IC so you just add a library to your sketch and assign the pinout and voltage in software.
  • And since I've already gone way out in left field, to complete the prefect conversion shield, add either an IC to linearly scale the analog inputs or a separate 5v 12 or 16 bit ADC
EDIT: Just read the post about the GTL2000 and it got me thinking there has got to be a chip that could route pins and shift logic levels... Yup.
http://www.intersil.com/en/products/audiovideo/video-switching/unbuffered-crosspoint-switches/CD22M3494.html
Thoughts?
OsuDan
Ok so here's the diagram of the circuit as I see it. Let me know what you guys think
Circuit for pins who's position might need to be changed
And here is for the other pins who's position is fixed
For both the CD22M3494 (crosspoint) and the SN74LVC16T245 (logic shifter) I think the buses can be 16 bit wide. As for going with the SN74LVC16T245 over the TXB0108, the advantage I see is that with the SN74LVC16T245, you can select each pin's output so some pins could interface with 5v logic, while others with devices at 3.3v. Might as well keep the shield dynamic as we can, especially if things really are moving towards 3.3v logic. Just my two cents, what's your guys reaction?
Dan
graynomad
I can't see where the data sheet says this is possible, apart from two OE and two DIR pins there are no control signals.
______
Rob
swseansw
I tried the TXB0108 and finally gave up.
The blue boxes in the attached picture contain 3 pcs pf TXB0108.
I made the beta board and tested it.
While I test the TXB0108 5V output with voltmeter, the voltage is 3V.
However, I test it with oscilloscope, the output is 5V. I touch the wire or chip with my finger, the voltage became unstable.
Well, I think, the TXB0108 is easy to go into self-excited oscillation process. And the load capacity is small. If I connect other devices to it through long cables, such as a digital sensor, the output may have problem. However, if I intert the sensor in the header of the beta DUE board directly, it works fine.
I tried many time but still didn't success.
Not sure if the TXB0108 performs not good enough.
OsuDan
______
Rob
Hey Rob,
Guess I had an optimistic read on that datasheet, you are right. Here is my solution.
With the setup, each pin can be selected as 3.3v or 5v through the MUX, then routed through the logic shifter if it is 5v. After that, the crosspoint handles the pin reassignment if needed. How about this? We getting close?
Dan
graynomad
I assume that all the data busses are 8 bits. I don't get how the Logic shifter has bi-directional signals. What's on the 3v3 side?
TBH I'm treating this as an academic exercise because it's interesting, personally I really can't see much use for such a complex shield but I'm happy to help with a design if you do.
_____
Rob
ogre
I have not looked at the circuits to evaluate....but i want one of these!
graynomad
#26
Dec 20, 2012, 08:00 am Last Edit: Dec 20, 2012, 08:08 am by Graynomad Reason: 1
Maybe there is a market after all, I always was 180 degrees out of phase with the consumer :)
Dan, my last question? How does the logic shifting circuit have bi-directional IO?
_____
Rob
ogre
_____
Rob
I would say if there is a market for the Due - then there is a market for this shield.  To choose the Due over the raspberry pi the main feature is the general purpose IO and the existing shields.  But to use either of these such a board is extremely useful.
Not only would a significant percentage of Due purchasers want such a shield- there would also be a market of people who current do NOT choose a Due to to shield incompatibility!
graynomad
I just thought I'd resurrect this thread because I now have a good reason to actually do something like this.
Did anyone take this any further?
Going back to something I missed in the original post by giantsfan3
the above level-translator IC based solution should work bi-directionally, for all signal types (digital I/O, PWM, analog lines, Serial, SPI, I2C),
Does the GTL2000 pass analog OK, it's only a few FETs so I would assume so but haven't tried it.
______
Rob
JChrispy58
I posted the question of how I can convert my 5 volt output from the hall effect sensors to a 3.3 volt output that the due can read.  I posted this in another forum.
I've been looking at these low voltage translators and I don't think I can use these.
I want the 3.3 volts to change linearly as the 5 volt changes...ie when I am getting 2.5 volts from the sensor the arduino should be reading 1.65 volts.
I'm not sure if I should just use a voltage divider because I'm concerned with accuracy to a certain degree.
Could you please help me out...this is for my senior design project.
