Topic: MIDI problems with PWM audio generator (Read 2085 times) previous topic - next topic
tonysnail
Hi..
I'm struggling with something - I'm working on an Arduino oscillator.. I'm using Adrian Freed's audio generator code (http://adrianfreed.com/content/arduino-sketch-high-frequency-precision-sine-wave-tone-sound-synthesis
I'm not sure if it's because the interrupt is hogging resources, but I can't seem to receive any MIDI data at the serial port..
I'm using the MIDI library - i've tried parsing MIDI.read in the main loop - and it doesn't work. I also tried it from within the interrupt, and even tried a counter that calls MIDI.read every 'x' number of cycles so the serial buffer has time to fill up, but it's no good.
Does anyone know a way to fix it? Perhaps I need to set up a separate interrupt just for MIDI - I know the audio code uses TIMER2, but I don't know how to make another interrupt..
Any thoughts would be greatly appreciated, I'm pulling my hair out!
Carl
Grumpy_Mike
While unfortunately I don't know what is wrong, this might help you from barking up the wrong tree:-
No the MIDI has it's own interrupt that is from the UART and nothing to do with timers.
It could be that the audio generator is spending too long in its Interrupt Service Routine to allow enough time for the serial to catch everything. Are you getting some data back through the MIDI channel even if it is incomplete?
tonysnail
I just tried disabling the interrupt and the MIDI works fine.. Guess I'll have to look at trimming back the interrupt code.. Unless there's a way to buffer the serial data from within the interrupt and check that?
cyclegadget
Good links: Eagle tutorial= http://www.youtube.com/playlist?list=PLDE1858BD83D19C70
General Arduion tutorials = http://tronixstuff.wordpress.com
http://www.gammon.com.au/forum/bbshowpost.php?bbtopic_id=123
