Topic: Nuovi sviluppi IDE 1.8.x (Read 397489 times) previous topic - next topic
PaoloP
Mar 11, 2013, 04:06 pm Last Edit: Mar 15, 2019, 07:27 pm by PaoloP
15/03/2019: Disponibile la versione 1.8.9
--> http://arduino.cc/en/Main/Software
ARDUINO 1.8.9 2019.03.15
[ide]
* New target! ARM64 boards are now fully supported (Nvidia Jetson and RaspberryPi3 with 64bit operating system)
* Fix UTF8 related bugs on Windows
* Fixed: can now compile again using OpenJDK (removed dependency on JavaFx)
* Fixed: only use touchBar on OSX 10.12 or higher
* PluggableDiscovery: easily add your own discoverer and make it available in Boards/Port menu (thanks @PaulStoffregen for the idea and the initial implementation)
* LibManager: reduce slowdown when searching
* Fixed: ensure a sketch line is visible when it contains an error and must be highlighted
* Linux: the installer now tries to install a symlink is /usr/local/bin (this doesn't affect usual non-systemwide installation) Thanks @2E0PGS
[wifi-updater]
* Fix firmware upgrade not being available for 3rd party WINC boards
[arduino-builder]
* Use lexicographic distance as last chance to spot the right library (if every other tecnique failed)
* Fix some prototypes being inserted in the middle of a function
ARDUINO 1.8.8 2018.12.07
[ide]
* Fixed: command line parsing of version parameters when installing cores/libraries
* Platform indexes are now downloaded using https
* Fixed: on some newer linux distributions, NPE when loading GTK look-and-feel without libgtk2 installed
* MacOSX: added touch bar support
* MacOSX: do not exit app after closing last window
* Fixed: serial monitor timestamps not always printed. Thanks @nitram509
* Kill active programmer if still alive after closing last IDE window
* Fixed: "Export compiled binary" now works also with unsaved sketches
* Improved automatic port re-selection after upload
* Added scroller to "INCOMPATIBLE" examples menu
[wifi-firmware]
* Added firmware upgrade for NINA-based boards
ARDUINO 1.8.7 2018.09.11
(bugfix service release)
[ide]
* Fixed: IDE doesn't start if library_index.json is corrupted.
* Fixed: IDE doesn't start if a library with invalid version is found.
* Fixed: Rare build errors in very complex sketches (like Marlin firmware).
* Fixed: Better dialog explaining that MacOSX 10.8 is now required. Thanks @PaulStoffregen
* Fixed: Slow "File" and "Tools" menus in MacOSX
* Fixed: Weird Board Manager behaviour if AVR core is downgraded to a version earlier than 1.6.22
* Improved first-use usability if the user don't select the serial port. Thanks @PaulStoffregen
* Custom "Tools" menu now keeps the order as defined in boards.txt.
[core]
* AVR: Fixed EEPROM warnings. Thanks @bxparks
* AVR: Treat "narrowing conversion" as warning, not error. This will make some libraries
       to compile again. Thanks @PaulStoffregen
23/08/2018: Disponibile la versione 1.8.6
ARDUINO 1.8.6 2018.08.23
[ide]
* Updated arduino-builder to 1.4.0:
  - parallel build (improve compile speed)
  - better reuse of already compiled files
  - Windows: fixed build for sketch stored under OneDrive cloud folders
* Added translations for library types. Thanks @ReAlUA
* Added scroller in programmers menu.
* Added "accelerator" in scrollable menu, press "a" key while scrolling
* Keep "Board Manager" menu item always as first in the menu
* "Manage Libraries" is now also in the "Tools" menu. Thanks @feikname
* Compiler errors now have both column and line
* Serial monitor how has "Show Timestamp" option. Thanks @MichalSy
* Improved DPI detection for hi-resolution montior on Linux
* Added copy/paste contextual menu in Find/Replace text fields
* Fixed long IDE startup time when some virtual/not-connected network interfaces are present
* Fixed inconsistent line-endings when saving files on Windows
* mdns: Make board disappear via TTL instead of reachability. Thanks @kurtgo
* Library Manager: display install/remove buttons with mouse on-hover instead of mouse click
* Board Manager: fixed some rare case with corrupted index download
* Windows: removed some debug output when running the IDE from command line
* Support selectable user-defined themes. User's theme are zip files inside the sketchbook "theme" folder
* Library Manager: library search now search also for headers (.h) declared by the library in library.properties
* Added "--version" to the CLI. Thanks @yohsuke
* Fixed Serial Plotter/Monitor permanently disabled if Plotter fails to open
* Fixed window title that sometimes is not updated on "Save as...". Thanks @JxJxJxMxNxS
* Fixed keybindings for Increase/Decrease font size
* Improved accessibility in the Preferences dialog. Thanks @coreyknapp
[core]
* AVR: Set Optiboot as default bootloader for Nano. This is the bootloader installed on new
       Arduino Nano boards. If you have a Nano with the old bootloader you must select
       Tools > Processor > ATmega328P (Old Bootloader) to upload.
* AVR core has been moved to its own repository: https://github.com/arduino/ArduinoCore-avr
* Updated toolchain to gcc 5.4.0
[wifi101-firmware]
* SECURITY FIX: Released fix for WPA2 KRACK vulnerability (latest WINC1500 firmware 19.5.2).
02/10/2017: Disponibile la versione 1.8.5
ARDUINO 1.8.5 2017.09.29
[ide]
* Added workaround for menu visibility bug in MacOSX 10.13 beta. Thanks @puybaret
* Fixed bug for negative-font-size.
* New/Rename tabs now allows names starting with a number.
23/08/2017: Disponibile la versione 1.8.4
ARDUINO 1.8.4 2017.08.23
[ide]
* IDE Toolbar can now go full width on 4K display.
* Environment variable LIBRARY_INDEX_URL is now correctly parsed (LIBRARY_INDEX_URL_GZ can also be optinally specified). Thanks @xardael
* Added per-board generic option in config file boards.txt for disabling control of dtr+rts. Thanks @d-a-v
* CLI: fixed missing "runtime.platform.path" when running without the `--board` option
* Linux: fixed desktop icon not launching the IDE in certain Window Managers (thanks @herrold)
* Allow setting low values for console size (correctly applies console.lines=x in preferences.txt)
* Make Preference window fit 600px height displays
* Fix error when renaming an unsaved, newly added file. Thanks @matthijskooijman
* Added the ability to increase/decrease font size via keyboard + mouse shortcuts (Ctrl + MouseWheel)
* Sketch names starting with a digit are now allowed
* Serial monitor is opened on a default position if the multi-monitor setup change (this should fix cases
  when the serial monitor is opened outside of the visibile space)
[libraries]
* Fixed wrong folder name for "Adafruit Circuit Playground" library, now it can be updated cleanly.
* Fixed wrong include for "RobotIRRemote", now it should not interfere anymore with the real IRRemote.
31/05/2017: Disponibile la versione 1.8.3
ARDUINO 1.8.3 2017.05.31
[ide]
* Fixed RESOURCE_NAME in install.sh script
* Serial Monitor: added "Clear output" button. Thanks @MichaelSy
* added options in preferences.txt for: custom title, comment/uncomment shortcut, always show file extensions. Thanks @MichaelSy
* added options in preferences.txt to enable/disable typing assistance (auto close brace, auto indent)
* Enabling "Use external editor" option now requires to save all sketches.
[core]
* AVR: added availableForWrite() method in generic Stream class. Thanks @eric-wieser
* AVR: moved flush() method up in the class hierarchy from Stream to Print class. Thanks @matthijskooijman
[other]
* Update Wifi101 Firmware Updater plugin
leo72
Io compilo dai repo ogni settimana, ho sempre la versione più aggiornata  :P
PaoloP
Aggiungo che, secondo me, le versione precedenti alla 1.0 dovrebbero essere considerate ormai deprecate.  :smiley-red:
leo72
Le versioni antecedenti alla 1.0.1, tra quelle deprecate ci metterei anche la 1.0 per i noti problemi relativi al bug dello sketch ArduinoISP.
menniti
NON SIA MAIIIIII!!! Ogni volta che qualcosa non va, cambio percorso e tiro fuori dalla sua cartella avvolta nel velluto, la mia fiera 0022, compagna di tante avventure e mai un tradimento :D
La 1.0 NON ha mai avuto il piacere di incontrare i miei computer  ]:D ne sono stato sempre fieramente alla larga.
Invece questo aggiornamento lo farò appena ho un minuto (circa Ferragosto, credo :smiley-sad-blue:)
Articoli ElettronicaIN
leo72
Neanch'io ho mai messo la 1.0, a dire il vero neanche la 0022, e sono passato direttamente alla 1.0.1.
Ma da quando ci fu quel problema con il menu a tendina di selezione della velocità seriale dell'IDE compilo sempre dai sorgenti.
astrobeed
Problema presente solo se usi la versione localizzata invece di quella in Inglese, mi pare sia ancora presente anche sulla 1.0.3, non ne sono sicuro perché io uso solo la versione in Inglese e mai quella localizzata in Italiano.
Scientia potentia est
leo72
E' stato risolto, non mi ricordo se nella 1.0.2 o nella 1.0.3
lestofante
1.0.2, l'ho scaricata apposta :-)
Jazzo
Fondamentale questo:
* Fixed memory leak when calling Ethernet.begin() multiple times
lestofante
uhmm in teoria la begin la dovresti chiamare una volta, e poi il resto sono server.available()..
QUETSO!  -----> Fixed malloc bug  <------ è il vero bug fix della versione
leo72
No, sei fuori strada  ;)
La 1.0.4 è stata rilasciata per introdurre la libreria GSM per il nuovo shield dell'Arduino di cui si parla qui  XD
astrobeed
Opinione personale, usare la malloc su un sistemino basato su una modesta mcu 8 bit con 2k di ram è come pestarsi le dita con una mazza da 5 kg  :smiley-mr-green:
PaoloP
Tra l'altro, secondo una roadmap apparsa tempo fa sulla mailing list, questa dovrebbe essere l'ultima versione della serie 1.0.x
Le prossima sarà la versione stabile della 1.5.x che ingloberà (com'è già adesso) anche il core di Arduino, oltre che quello della DUE.
Inoltre stanno sviluppando un repository unificato per le librerie di terze parti.
lestofante
ma se non erro la malloc viene usata molto spesso nelle librerie arduino, in primis la String, che usiamo praticamente tutti.
