Topic: Problems with ATMega328? (The one without the P?) (Read 2152 times) previous topic - next topic
NinoScript
At least in Chile, I could only find the ATMega328, not the ATMega328P; there's an issue with the chip's signature.
I solved the issue by adding the extra chip in both the boards.txt
Code: [Select]
atmega328.name=Arduino Duemilanove w/ ATmega328 that has no P
atmega328.upload.protocol=arduino
atmega328.upload.maximum_size=30720
atmega328.upload.speed=57600
atmega328.bootloader.low_fuses=0xFF
atmega328.bootloader.high_fuses=0xDA
atmega328.bootloader.extended_fuses=0x05
atmega328.bootloader.path=arduino:atmega
atmega328.bootloader.file=ATmegaBOOT_168_atmega328.hex
atmega328.bootloader.unlock_bits=0x3F
atmega328.bootloader.lock_bits=0x0F
atmega328.build.mcu=atmega328
atmega328.build.f_cpu=16000000L
atmega328.build.core=arduino:arduino
and in avrdude.conf
Code: [Select]
# ATmega328
part
    id = "m328";
    desc = "ATMEGA328";
    has_debugwire = yes;
    flash_instr = 0xB6, 0x01, 0x11;
    eeprom_instr = 0xBD, 0xF2, 0xBD, 0xE1, 0xBB, 0xCF, 0xB4, 0x00,
  0xBE, 0x01, 0xB6, 0x01, 0xBC, 0x00, 0xBB, 0xBF,
  0x99, 0xF9, 0xBB, 0xAF;
    stk500_devcode = 0x86;
    # avr910_devcode = 0x;
    signature = 0x1e 0x95 0x14;
    pagel = 0xd7;
    bs2 = 0xc2;
    chip_erase_delay = 9000;
    pgm_enable = "1 0 1 0 1 1 0 0 0 1 0 1 0 0 1 1",
"x x x x x x x x x x x x x x x x";
    chip_erase = "1 0 1 0 1 1 0 0 1 0 0 x x x x x",
    timeout = 200;
    stabdelay = 100;
    cmdexedelay = 25;
    synchloops = 32;
    bytedelay = 0;
    pollindex = 3;
    pollvalue = 0x53;
    predelay = 1;
    postdelay = 1;
    pollmethod = 1;
    pp_controlstack =
0x0E, 0x1E, 0x0F, 0x1F, 0x2E, 0x3E, 0x2F, 0x3F,
0x4E, 0x5E, 0x4F, 0x5F, 0x6E, 0x7E, 0x6F, 0x7F,
0x66, 0x76, 0x67, 0x77, 0x6A, 0x7A, 0x6B, 0x7B,
0xBE, 0xFD, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00;
    hventerstabdelay = 100;
    progmodedelay = 0;
    latchcycles = 5;
    togglevtg = 1;
    poweroffdelay = 15;
    resetdelayms = 1;
    resetdelayus = 0;
    hvleavestabdelay = 15;
    resetdelay = 15;
    chiperasepulsewidth = 0;
    chiperasepolltimeout = 10;
    programfusepulsewidth = 0;
    programfusepolltimeout = 5;
    programlockpulsewidth = 0;
    programlockpolltimeout = 5;
    memory "eeprom"
paged = no;
page_size = 4;
size = 1024;
min_write_delay = 3600;
max_write_delay = 3600;
readback_p1 = 0xff;
readback_p2 = 0xff;
read = " 1 0 1 0 0 0 0 0",
       " 0 0 0 x x x a9 a8",
       " a7 a6 a5 a4 a3 a2 a1 a0",
       " o o o o o o o o";
write = " 1 1 0 0 0 0 0 0",
" i i i i i i i i";
loadpage_lo = " 1 1 0 0 0 0 0 1",
      " 0 0 0 0 0 0 0 0",
      " 0 0 0 0 0 0 a1 a0",
      " i i i i i i i i";
writepage = " 1 1 0 0 0 0 1 0",
    " 0 0 x x x x a9 a8",
    " a7 a6 a5 a4 a3 a2 0 0",
    " x x x x x x x x";
mode = 0x41;
delay = 20;
blocksize = 4;
readsize = 256;
    memory "flash"
paged = yes;
size = 32768;
page_size = 128;
num_pages = 256;
min_write_delay = 4500;
max_write_delay = 4500;
readback_p1 = 0xff;
readback_p2 = 0xff;
read_lo = " 0 0 1 0 0 0 0 0",
  " 0 0 a13 a12 a11 a10 a9 a8",
  " o o o o o o o o";
read_hi = " 0 0 1 0 1 0 0 0",
  " o o o o o o o o";
loadpage_lo = " 0 1 0 0 0 0 0 0",
      " 0 0 0 x x x x x",
      " x x a5 a4 a3 a2 a1 a0",
      " i i i i i i i i";
loadpage_hi = " 0 1 0 0 1 0 0 0",
      " 0 0 0 x x x x x",
      " i i i i i i i i";
writepage = " 0 1 0 0 1 1 0 0",
    " a7 a6 x x x x x x",
    " x x x x x x x x";
mode = 0x41;
delay = 6;
blocksize = 128;
readsize = 256;
    memory "lfuse"
size = 1;
read = "0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0",
       "x x x x x x x x o o o o o o o o";
write = "1 0 1 0 1 1 0 0 1 0 1 0 0 0 0 0",
      "x x x x x x x x i i i i i i i i";
    memory "hfuse"
size = 1;
read = "0 1 0 1 1 0 0 0 0 0 0 0 1 0 0 0",
write = "1 0 1 0 1 1 0 0 1 0 1 0 1 0 0 0",
    memory "efuse"
size = 1;
read = "0 1 0 1 0 0 0 0 0 0 0 0 1 0 0 0",
       "x x x x x x x x x x x x x o o o";
write = "1 0 1 0 1 1 0 0 1 0 1 0 0 1 0 0",
      "x x x x x x x x x x x x x i i i";
    memory "lock"
size = 1;
read = "0 1 0 1 1 0 0 0 0 0 0 0 0 0 0 0",
       "x x x x x x x x x x o o o o o o";
write = "1 0 1 0 1 1 0 0 1 1 1 x x x x x",
      "x x x x x x x x 1 1 i i i i i i";
    memory "calibration"
size = 1;
read = "0 0 1 1 1 0 0 0 0 0 0 x x x x x",
       "0 0 0 0 0 0 0 0 o o o o o o o o";
    memory "signature"
size = 3;
read = "0 0 1 1 0 0 0 0 0 0 0 x x x x x",
       "x x x x x x a1 a0 o o o o o o o o";
I thought it could be helpful to someone. :)
eried
#1
Sep 11, 2012, 05:48 am Last Edit: Sep 11, 2012, 06:02 am by eried Reason: 1
Genial, hace menos de una semana un amigo me comentó que no había podido usar el atmega de olimex, debió ser esto.
My website: http://ried.cl
NinoScript
Yes, that's exactly it; MCI ltda. (aka olimex.cl) only sells the power hungry version.
eried
Nice. I added your board definition in the mod :D
CrossRoads
Could you add similar definitions for 1284 & 1284P?
NinoScript
I could try… but I don't think I can.
I don't really know what all of that means, I just knew that the ATMega328 is exactly the same as the ATMega328P but with a different signature.  :smiley-fat:
eried
http://arduino.cc/forum/index.php/topic,118440.0.html :) board is included now! thanks
eraticus
Hello Experts,
I am in a similar situation, after being given ATMEGA 328-PU chips to works with. I am trying to follow these instructions, but cannot find the avrdude.conf file. I am using macintosh computer, which might put me at a disadvantage :( Does anyone know where the avrdude.comf file is on a mac install of arduino?
CrossRoads
Do a simple search. Easy to find in arduino path.
