Topic: Ardutester - Arduino Component Tester (Read 46871 times) previous topic - next topic
mrburnette
Rambling around the Internet trying to catch-up on my reading, I found myself on the Ops webpages:
http://www.pighixxx.com/myblog/
As of October 17, he was still alive and blogging.  However, his Ardutester page seems to be unedited for some time: http://www.pighixxx.com/tag/ardutester/
Early versions of the port seemed to work OK but the embellishments eventually caused the software which is available in the #1 post to be unstable - in my case, unusable.  I see that others have had similar "weird" results, too.
I am wondering if this is just one of those projects that comes out kickin' and screamin' but dies before it is finished?
"che sarà, sarà"
Ray
Petruce
Bonjour,
Merci de votre travail.
Quelques erreurs de mesures m'ont été données.
J'ai intercalé un potentiomètre entre le  5v et GND le point milieu raccorder à la broche AREF.
Les erreurs ont été corrigées avec une tension de 0.84V.
Est-ce une bonne ou mauvaise idée?
En vous remerciant par avance.
mrburnette
Quote
Hello,
Thank you for your work.
Some measurement errors were given to me.
I inserted a potentiometer between 5V and GND the midpoint connected to the AREF pin.
The errors have been corrected with a voltage of 0.84V.
Is this a good or bad idea?
Thanking you in advance.
@Petruce,
I no longer have my tester on the solderless breadboard.  If I get some free time, I'll will try repeating your suggestion.
Thank you,
Ray
polymorph
Is it perhaps not zeroing out the stray capacitance correctly?
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - tinyurl.com/q7uqnvn
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
limbo
Can anyone provide links for the latest schematic and firmware (sketch)?
It seems pighi's web site is  down for a long period of time and all the links are dead.
mrburnette
I gave up on the code because it had too many issues.  The older code worked OK but the rewrite did strange things, documented elsewhere.  Even when the site was up, only the most recent code was available.
From the code header:
Code: [Select]
ARDUTESTER v0.X 25/04/2013
Original Source from:        http://www.mikrocontroller.net/articles/AVR-Transistortester
Original Software:           by Karl-Heinz Kuebbeler (kh_kuebbeler@web.de)
                              The Ardutester software is based on porting by Markus Reschke (madires@theca-tabellaria.de)
Schematic & Home Page:       http://www.pighixxx.com/lavori/ardutester/
Arduino version:             PighiXXX (info@pighixxx.com)
                              PaoloP (http://www.arduino.cc/forum/index.php?action=profile;u=58300)
agent006
I have a couple of versions, but which one would you recommend me trying?
Thanks
Anthony
mrburnette
Thanks
Anthony
Gee, hard to say... Go to the oldest and try that, if it works OK, then move forward in time.  The damage I noticed showed up with diodes getting misclassified and even the anode/cathode getting swapped sometimes... Also, some weird menu problems but I cannot remember the specifics.
Ray
pfeifei
hello
I'm new here in the forum
I would like to try the Ardutester
Unfortunately, the download link for the sketch and the circuit does not work.
can someone send me the files?
thanks
Peter
ChilliTronix
uuygaar
Guys i want to do ardutester , but there is no working links , can you help to me for this situation ?
billhowl
I only have older code
azhnf
Hi everyone, i can't download schematic from pighixxx web. does anyone have the schematic ?
sorry bad english.
ozolive
Hi everybody.
As i started looking into this, i found news which i feels deserve to be mentionned in this thread.
Actually the project from which pighixxx based his ArduTester is very up and alive.
It looks very well maintained by Karl-Heinz Kübbeler and other contributors at http://www.mikrocontroller.net/articles/AVR_Transistortester#Introduction_.28English.29 .
The SVN accessible there shows at least 2 current versions, with many screen options :)
As the project seems quite mature, i might assemble mine sooner or later. Big thanks to all contributors !
