Topic: 8x8 rgb colorduino help (Read 2709 times) previous topic - next topic
hellzangel990
I have a code but it keeps throwing errors and I cant find the problem if anyone can help me please
Code: [Select]
#include <Wire.h>
#include <avr/pgmspace.h>
define the operate commands
define the status
define the IO
#define RST_BIT 0x04
#define LAT_BIT 0x02
#define SLB_BIT 0x01
#define SCL_BIT 0x40
#define SDA_BIT 0x80
#define RST PORTC
#define LAT PORTC
#define SLB PORTC
#define SDA PORTD
#define SCL PORTD
#define open_line0 {PORTB=0x01;}
#define open_line1 {PORTB=0x02;}
#define open_line2 {PORTB=0x04;}
#define open_line3 {PORTB=0x08;}
#define open_line4 {PORTB=0x10;}
#define open_line5 {PORTB=0x20;}
#define open_line6 {PORTD=0x08;}
#define open_line7 {PORTD=0x10;}
#define close_all_line {PORTD=0x00;PORTB=0x00;}
define the data zone
//Test dots
unsigned char Tdots[8][8][3]=     {{{0,0,255},     {0,0,255},      {0,0,255},     {0,0,255},    {0,0,255},      {0,0,255},       {0,0,255},        {0,0,255}},
                                  {{0,165,255},   {0,165,255},    {0,165,255},   {0,165,255},  {0,165,255},    {0,165,255},     {0,165,255},      {0,165,255}},
                                  {{0,255,255},   {0,255,255},    {0,255,255},   {0,255,255},  {0,255,255},    {0,255,255},     {0,255,255},      {0,255,255}},
                                  {{0,255,0},     {0,255,0},      {0,255,0},     {0,255,0},    {0,255,0},      {0,255,0},       {0,255,0},        {0,255,0}},
                                  {{255,127,0},   {255,127,0},    {255,127,0},   {255,127,0},  {255,127,0},    {255,127,0},     {255,127,0},      {255,127,0}},
                                  {{255,0,0},     {255,0,0},      {255,0,0},     {255,0,0},    {255,0,0},      {255,0,0},       {255,0,0},        {255,0,0}},
                                  {{255,0,139},   {255,0,139},    {255,0,139},   {255,0,139},  {255,0,139},    {255,0,139},     {255,0,139},      {255,0,139}},
                                  {{255,255,255}, {255,255,255},  {255,255,255}, {255,255,255},{255,255,255},  {255,255,255},   {255,255,255},    {255,255,255}}
unsigned char dots[2][8][8][3] = {0};
//dots matrix
//[2]:Page:one for display, one for receive data
//[8]:Row:8 row in LED plane
//[8]:Column:8 column in one row
//[3]:Color:RGB data: 0 for Red; 1 for green, 2 for Blue
unsigned char Gamma_Value[3] = {10,63,63};
//Gamma correctly value, every LED plane is different.value range is 0~63
//[3]:RGB data, 0 for Red; 1 for green, 2 for Blue
unsigned char Page_Index = 0; // the index of buffer
unsigned char row = 0;//the value of row in LED plane, from 0~7
unsigned char column = 0;//the value of every row, from 0~7
unsigned char color = 0;//the value of every dots, 0 is Red, 1 is Green, 2 is Blue
unsigned char line = 0;
define the extern data zone
extern unsigned char font8_8[92][8];
extern unsigned char pic[4][8][8][3];
all parts inition functions zone
void _IO_Init()
  DDRD = 0xff; // set all pins direction of PortD
  DDRC = 0xff; // set all pins direction of PortC
  DDRB = 0xff; // set all pins direction of PortB
  PORTD = 0x00; // set all pins output is low of PortD
  PORTC = 0x00; // set all pins output is low of PortC
  PORTB = 0x00; // set all pins output is low of PortB
void _LED_Init()
  LED_RST(1);
  LED_Delay(1);
  LED_RST(0);
  LED_Delay(1);
  LED_RST(1);
  LED_Delay(1);
  SetGamma();
  line = 0;
void _TC2_Init()
  TCCR2A |= (1 << WGM21) | (1 << WGM20);
  TCCR2B |= ((1<<CS22)|(1<<CS20));   // by clk/64
  TCCR2B &= ~((1<<CS21));   // by clk/64
  TCCR2A &= ~((1<<WGM21) | (1<<WGM20));   // Use normal mode
  ASSR |= (1<<AS2);       // Use internal clock - external clock not used in Arduino
  TIMSK2 |= (1<<TOIE2) | (0<<OCIE2B);   //Timer2 Overflow Interrupt Enable
  TCNT2 = 0xff;
  sei();
the timer2 operate functions zone
ISR(TIMER2_OVF_vect)          //Timer2  Service
  cli();
  TCNT2 = 0x64;      //flash a led matrix frequency is 100.3Hz,period is 9.97ms
  //TCNT2 = 0x63;      //flash a led matrix frequency is 99.66Hz,period is 10.034ms
    if(line > 7) line = 0;
    close_all_line;
    run(line);
    open_line(line);
    line++;
    sei();
the LED Hardware operate functions zone
void LED_SDA(unsigned char temp)
  if (temp)
    SDA|=SDA_BIT;
    SDA&=~SDA_BIT;
void LED_SCL(unsigned char temp)
  if (temp)
    SCL|=SCL_BIT;
    SCL&=~SCL_BIT;
void LED_RST(unsigned char temp)
  if (temp)
    RST|=RST_BIT;
    RST&=~RST_BIT;
void LED_LAT(unsigned char temp)
  if (temp)
    LAT|=LAT_BIT;
    LAT&=~LAT_BIT;
void LED_SLB(unsigned char temp)
  if (temp)
    SLB|=SLB_BIT;
    SLB&=~SLB_BIT;
the LED datas operate functions zone
void SetGamma()
  unsigned char i = 0;
  unsigned char j = 0;
  unsigned char k = 0;
  unsigned char temp = 0;
  LED_LAT(0);
  LED_SLB(0);
  for(k=0;k<8;k++)
    for(i = 3;i > 0 ;i--)
      temp = Gamma_Value[i-1]<<2;
      for(j = 0;j<6;j++)
        if(temp &0x80)
          LED_SDA(1);
          LED_SDA(0);
        temp =temp << 1;
        LED_SCL(0);
        LED_SCL(1);
  LED_SLB(1);
void run(unsigned char k)
  unsigned char p = 0;
  LED_SLB(1);
  LED_LAT(0);
  for(i = 0;i<8;i++)
    for(j=0;j<3;j++)
      temp = dots[Page_Index][k][i][2-j];
      for(p=0;p<8;p++)
         if(temp & 0x80)
           LED_SDA(1);
           LED_SDA(0);
         temp = temp<<1;
         LED_SCL(0);
         LED_SCL(1);
  LED_LAT(1);
  LED_LAT(0);
void open_line(unsigned char x)
  switch (x)
    case 0 :open_line0;
    case 1 :open_line1;
    case 2 :open_line2;
    case 3 :open_line3;
    case 4 :open_line4;
    case 5 :open_line5;
    case 6 :open_line6;
    case 7 :open_line7;
    default: close_all_line;
Function:Display a English latter in LED matrix
Parameter:chr :the latter want to show
          R: the value of RED.   Range:RED 0~255
          G: the value of GREEN. Range:RED 0~255
          B: the value of BLUE.  Range:RED 0~255
          bias: the bias of a letter in LED Matrix.Range -7~7
void DispShowChar(char chr,unsigned char R,unsigned char G,unsigned char B,char bias)
  unsigned char i,j,Page_Write,temp;
  unsigned char Char;
  unsigned char chrtemp[24] = {0};
  if ((bias > 8) || (bias < -8))
    return;
  Char = chr - 32;
  if(Page_Index == 0)
    Page_Write = 1;
  if(Page_Index == 1)
    Page_Write = 0;
  j = 8 - bias;
  for(i = 0;i< 8;i++)
    chrtemp[j] = pgm_read_byte(&(font8_8[Char][i]));
    j++;
  for(i = 0;i < 8;i++)
    temp = chrtemp[i+8];
    for(j = 0;j < 8;j++)
      if(temp & 0x80)
        dots[Page_Write][j][i][0] = B;
        dots[Page_Write][j][i][1] = G;
        dots[Page_Write][j][i][2] = R;
        dots[Page_Write][j][i][0] = 0;
        dots[Page_Write][j][i][1] = 0;
        dots[Page_Write][j][i][2] = 0;
      temp = temp << 1;
  Page_Index = Page_Write;
Function:Fill a color in LED matrix
Parameter:R: the value of RED.   Range:RED 0~255
hellzangel990
heres the rest of it
Code: [Select]
void DispShowColor(unsigned char R,unsigned char G,unsigned char B)
  unsigned char Page_Write,i,j;
  if(Page_Index == 0)
    Page_Write = 1;
  if(Page_Index == 1)
    Page_Write = 0;
  for (i = 0;i<8;i++)
    for(j = 0;j<8;j++)
      dots[Page_Write][i][j][2] = R;
      dots[Page_Write][i][j][1] = G;
      dots[Page_Write][i][j][0] = B;
Function:Fill a picture in LED matrix from FLASH
Parameter:Index:the index of picture in Flash.
void DispShowPic(unsigned char Index)
  if(Page_Index == 0)
    Page_Write = 1;
  if(Page_Index == 1)
    Page_Write = 0;
  for (i = 0;i<8;i++)
    for(j = 0;j<8;j++)
      dots[Page_Write][i][j][0] = pgm_read_byte(&(pic[Index][i][j][2]));
      dots[Page_Write][i][j][1] = pgm_read_byte(&(pic[Index][i][j][1]));
      dots[Page_Write][i][j][2] = pgm_read_byte(&(pic[Index][i][j][0]));
the other operate functions zone
void LED_Delay(unsigned char i)
  unsigned int y;
  y = i * 10;
  while(y--);
Main Functions zone
  _IO_Init();           //Init IO
  _LED_Init();          //Init LED Hardware
  _TC2_Init();          //Init Timer/Count2
  unsigned int i = 1000;
  char j=0;
  DispShowChar('A',255,0,0,0);
  delay(i);
  DispShowChar('B',0,255,0,0);
  delay(i);
  DispShowChar('C',0,0,255,0);
  delay(i);
  DispShowChar('D',255,255,255,0);
  delay(i);
  DispShowChar('E',0,255,255,0);
  delay(i);
  DispShowChar('F',255,255,0,0);
  delay(i);
  DispShowChar('G',255,0,255,0);
  delay(i);
  DispShowChar('H',255,127,0,0);
  delay(i);
  DispShowChar('I',127,255,0,0);
  delay(i);
  DispShowChar('J',127,0,255,0);
  delay(i);
  DispShowChar('K',255,127,127,0);
  delay(i);
  DispShowChar('L',127,127,255,0);
  delay(i);
  DispShowChar('M',127,255,127,0);
  delay(i);
  DispShowChar('N',255,127,255,0);
  delay(i);
  DispShowChar('O',200,120,120,0);
  delay(i);
    DispShowChar('P',120,200,120,0);
  delay(i);
  DispShowChar('Q',200,120,120,0);
  delay(i);
  DispShowChar('R',120,120,200,0);
  delay(i);
  DispShowChar('S',120,120,120,0);
  delay(i);
  DispShowChar('T',127,0,100,0);
  delay(i);
  DispShowChar('U',255,0,200,0);
  delay(i);
   DispShowChar('V',200,255,120,0);
  delay(i);
  DispShowChar('W',120,200,200,0);
  delay(i);
  DispShowChar('X',200,200,120,0);
  delay(i);
  DispShowChar('Y',127,0,180,0);
  delay(i);
  DispShowChar('Z',0,1800,200,0);
  delay(i);
  DispShowChar('a',255,0,0,0);
  delay(i);
  DispShowChar('b',0,255,0,0);
  delay(i);
  DispShowChar('c',0,0,255,0);
  delay(i);
  DispShowChar('d',255,255,255,0);
  delay(i);
  DispShowChar('e',0,255,255,0);
  delay(i);
  DispShowChar('f',255,255,0,0);
  delay(i);
  DispShowChar('g',255,0,255,0);
  delay(i);
  DispShowChar('h',255,127,0,0);
  delay(i);
  DispShowChar('i',127,255,0,0);
  delay(i);
  DispShowChar('j',127,0,255,0);
  delay(i);
  DispShowChar('k',255,127,127,0);
  delay(i);
  DispShowChar('l',127,127,255,0);
  delay(i);
  DispShowChar('m',127,255,127,0);
  delay(i);
  DispShowChar('n',255,127,255,0);
  delay(i);
  DispShowChar('0',200,120,120,0);
  delay(i);
  DispShowChar('p',120,200,120,0);
  delay(i);
  DispShowChar('q',200,120,120,0);
  delay(i);
  DispShowChar('r',120,120,200,0);
  delay(i);
  DispShowChar('s',120,120,120,0);
  delay(i);
  DispShowChar('t',127,0,100,0);
  delay(i);
  DispShowChar('u',255,0,200,0);
  delay(i);
   DispShowChar('v',200,255,120,0);
  delay(i);
  DispShowChar('w',120,200,200,0);
  delay(i);
  DispShowChar('x',200,200,120,0);
  delay(i);
  DispShowChar('y',127,0,180,0);
  delay(i);
  DispShowChar('z',0,1800,200,0);
  delay(i);
  delay(i);
  DispShowChar('1',120,120,200,0);
  delay(i);
  DispShowChar('2',120,120,120,0);
  delay(i);
  DispShowChar('3',127,0,100,0);
  delay(i);
  DispShowChar('4',255,0,200,0);
  delay(i);
   DispShowChar('5',200,255,120,0);
  delay(i);
  DispShowChar('6',120,200,200,0);
  delay(i);
  DispShowChar('7',200,200,120,0);
  delay(i);
  DispShowChar('8',127,0,180,0);
  delay(i);
  DispShowChar('9',0,1800,200,0);
  delay(i);
  DispShowPic(0);
  delay(i);
  DispShowPic(1);
  delay(i);
  DispShowPic(2);
  delay(i);
  DispShowPic(3);
  delay(i);
  for(j = -7;j < 7;j++)
    DispShowChar('I',255,255,0,j);
    delay(i);
    DispShowChar('t',0,255,255,j);
    delay(i);
    DispShowChar('e',255,0,255,j);
    delay(i);
    DispShowChar('a',255,255,255,j);
    delay(i);
    DispShowChar('d',255,255,255,j);
    delay(i);
    DispShowChar('s',255,255,255,j);
    delay(i);
    DispShowChar('t',255,255,255,j);
    delay(i);
    DispShowChar('u',255,255,255,j);
    delay(i);
    delay(i);
    DispShowChar('i',255,255,255,j);
    delay(i);
    DispShowChar('o',255,255,255,j);
    delay(i);
  DispShowPic(0);
  delay(i);
  DispShowPic(1);
  delay(i);
  DispShowPic(2);
  delay(i);
  DispShowPic(3);
  delay(i);
  DispShowPic(4);
  delay(i);
  DispShowPic(5);
  delay(i);
hellzangel990
error's
expected`)' before ' volatile'
expected unqualified-id before 'volatile'
billhowl
You need to include this a the start of the code
Code: [Select]
#include "Arduino.h"
hellzangel990
now its saying undefined reference to `pic'
