Topic: "global hello" (Read 1 time) previous topic - next topic
boinerz
May 17, 2013, 12:33 am Last Edit: May 17, 2013, 12:43 am by boinerz Reason: 1
Code: [Select]
/* GlobalHello
Echos a char value sent via USB input back to the terminal application.
Initializes returning first keypress as identifier string.
const char* global_hello = "ARDUINO";
int charVal;
 splash();
void splash(){
 while (!Serial.available()){
 Serial.println(global_hello);
 if (Serial.available()){
   charVal = Serial.read();
 if (charVal){
     digitalWrite(13, HIGH); // set LED on
     delay(5); // wait
     Serial.write(charVal);
     Serial.write(32); // space to obviate TX emanation
     charVal = 0;
     digitalWrite(13, LOW); // set LED off
     delay(5); // wait
robtillaart
Nice echo program, is there any question involved?  //otherwise you better posted it in exhibition section
Tip for expanding, let the LED blink the char in morse or #times the ascii value represents
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
boinerz
YEP,, THX,
It can be improved into a useful development/debug component, modified and retained. The splash is useful, responds to single key-press in the VB terminal.
It works well with a VB-compiled terminal I use as basis for configuration via USB.
