Topic: Digital I/O Router/switch - What options are available? (Read 3167 times) previous topic - next topic
Protoneer
Hi...
Have been searching online but could not find anything except networking equipment.
Is there some sort of integrated circuit available that can do routing / switching of IO(Input / Output) lines?
Example, if you have 5 input and output lines I would like to be able to change how input pins are forwarded
to the output pin. A real world example of this would be like the old phone exchanges where the operators routed incoming
callers lines to specific receiver lines.
I know automated phone exchanges can do this somehow.
Any suggestions or pointing in the right direction would be appreciated.
Thanks.
Delta 3D Printer with Auto Bed Leveling - http://www.kickstarter.com/projects/ttstam/openbeam-kossel-pro-a-new-type-of-3d-printer/posts
http://blog.Protoneer.co.nz
nickgammon
Multiplexer:
http://www.gammon.com.au/forum/?id=11976
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
Protoneer
That's exactly what I am after... Thanks for that Nick.
Now I have a name I can do some reading up on... ;)
cmiyc
A more relevant example is the analog inputs of your Arduino.  There is only one A/D in the chip.  The 6 analog inputs are connected to an Analog-Multiplexer (also on chip), which gives multiple analog inputs.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
Protoneer
I see. I was wondering about that.. So a port extender is then the same thing,right?
nickgammon
It's a bit different because the multiplexer handles analog inputs, but a port extender basically just outputs low or high. I suppose it depends on your definition of those words.
Protoneer
Thanks for pointing that out... A multiplexer will actually be more useful because like the Arduino analog pins, you can also make them act like Digital pins.
graynomad
Quote
to the output pin.
This is more an app for a crosspoint switch, you can get them in 8x8, 8x16 etc. An 8x8 is basically 8 8-way MUXes in a single chip.
_____
Rob
Rob Gray aka the GRAYnomad www.robgray.com
Protoneer
Hi Rob... Do you have an example of an IC that I can go an look-up?
graynomad
#9
Jul 08, 2013, 11:01 am Last Edit: Jul 08, 2013, 11:47 am by Graynomad Reason: 1
There aren't that many I think, I have data sheets for these ones
AD75019
CD22M3494
M22100
MAX4359-MAX4456
EDIT: Crosspoint switches are mostly used in telecoms and are analogue but still switch digital. If you have a digital application one way to do it is to use a SRAM chip and program the bits to provide the transfer function you want, I've never done it but I would think it would work. Also if the speeds are real fast you could dedicate a CPU to the job, read 8 bits, index into a table, write 8 bits.
_____
Rob
pwillard
I personally used a 22100 in a matrix scanned keyboard solution to "simulate" key-presses... though I think that part is considered quite obsolete now.
