Topic: Arduino hangs on Bridge.begin() (Read 9300 times) previous topic - next topic
HSpaigu
@jessemonroy650 @alexafa
hi, i meet the same problem and want to try this way, but i dont know how to save and exit?
ps: i use puTTy to ssh to the arduino
jessemonroy650
::::SNIP:::
@HSpaigu
"Save and exit" what?
Jesse
HSpaigu
@HSpaigu
Jesse
@jessemonroy650
i meet the problem that the sketch does not run bridge.begin(), at #13,  @alexafa has found a solution, he says need to create a new file K49stop-mcu
but i dont know how to do this.
i ssh into the linux side, go to the directory: /etc/rc.d/
and then type
Code: [Select]
#nano K49stop-mcu
#!/bin/sh
echo 18 > /sys/class/gpio/export
echo "high" > /sys/class/gpio/gpio18/direction
echo 1 > /sys/class/gpio/gpio18/value
echo 18 > /sys/class/gpio/unexport
but after these, the file K49stop-mcu not be created
jessemonroy650
@HSpaigu
okay,
DO NOT create file in /etc/rc.d
CREATE file in /etc/init.d
After create file, chmod 755 stop-mcu;
then make link from rc.d to file. Use ln(1) to make link. Do you know how to do this?
With editor
When using nano, see bottom. You should see ^X Exit
When you press, control-x you should exit editor.
It will ask
Save modified buffer (ANSWERING "No" WILL DESTROY CHANGES) ?
Press button 'y'.
It will ask you to confirm the new name (or current name).
Then do
Any Questions?
Jesse
HSpaigu
@jessemonroy650
thank you!
however the bridge.begin() still not works, the sketch run to the bridge.begin(), then hang on, ive already try many ways, but not work:
1, upgrade to the latest lininoIO
2, remove python-firmata and pyserial
3, change bridge.begin() to bridge.begin(250000)
4, create stop-mcu in /etc/rc.d or /etc/init.d
almost give up, find arduino yun has so many problems
jessemonroy650
@HSpaigu,
Your message are quite unclear. In addition, it appears you have purchased a Yun from Arduino.org. As such, I am going to discontinue this conversation. Please use the forum on Arduino.org
If you are having a problem understanding, please from this forum the recent posts
- Arduino Yún Retirement and Replacement
- @Angelo9999 please consider shutting down this forum channel
- Arduino Yún .CC vs .ORG Compatibility?
Best of Luck
Jesse
novski
#21
Mar 12, 2019, 11:26 am Last Edit: Mar 12, 2019, 11:27 am by novski
Hello!
This is my solution.
Create a new file int '/etc/rc.d/' named 'K49stop-mcu' (Scripts that run at shutdown)
#nano K49stop-mcu
Add this content:
 #!/bin/sh
Save, exit and change permissions:
    chmod 7777 K49stop-mcu
It is done.
MCU stops before restarting and so the bridge does not fail booting Linino.
this seams logic. for those who feel  like a bit more education cold help: https://unix.stackexchange.com/a/310132
