Topic: How to disable WiFi on Yun ? (Read 2524 times) previous topic - next topic
te36
How do i disable the wifi on Yun ?
I went to the Yun config GUI, unclicked "configure a wireless network", clicked "configure & restart", but after i restarted, my notebook would still see the Arduino SSID.
te36
To answer my own question:
1. Comment out wifi-live-or-reset in /etc/rc.local
2. Go to /etc/modules.d, move away all kernel modules for the wireless interface, e.g.:
  chdir /etc/modules.d
   mkdir .NOT
   mv 26-ath 27-ath9k-common 28-ath9k 50-wdt-ath79 .NOT
Reboot, and there will be no wireless interface.
No idea whether this is the easiest way to achieve this goal, but looking through all the init scripts, i couldn't figure out an esker way. Especailly this "wifi-live-or-reset" is a real nasty piece of system config, especially when you do not know about it, and for example try to disable the wifi interface in the expanded config web interface - and get periodic reboots after 2 minutes or so.
sonnyyu
armadillo66
affter run that procedure, it's possible to turn the wifi enable back ?
federicofissore
Yes, do the contrary of what the procedure says http://playground.arduino.cc/Hardware/Yun#disable_wifi
armadillo66
The Arduino Yun wi-fi works pretty nice, so far I test it, i like it more and more, but I think the Linux get corrupted,  at any try to get conection by wifi or ethernet, the navigator start with arduino blue screen  then  stop and the navigator show the standard conection fault message.
federicofissore
Just to remove the easy problems: have you upgraded the yun with the latest image? http://forum.arduino.cc/index.php?topic=235360.0
fsenftle
Please let me know if there's anyway to turn off the Arduino Yun WiFi.
I need to do this under the Arduino IDE with windows 7 (not LINUX).
After trying all suggestions from different posts/forums.
None worked as after 5 minutes the WiFi is enabled again.
None of these suggestions worked:
https://forum.arduino.cc/index.php?topic=189105.0
https://gist.github.com/sgk/6641198
https://gist.githubusercontent.com/sgk/6641198/raw/c6c36b2c8a9d62036b11335f6515ce3c5ce03ee6/PatchYun.ino
Please advise which forum I can ask this on, etc.
Your advise is greatly appreciated.
