Topic: Ethernet Shield USB/Serial input (Read 279 times) previous topic - next topic
spicetraders
The older ArduinoBoardEthernet has the 6 pin connector for serial input to the unit.  But no 6 pin connector is found on the Arduino Ethernet Shield board.  How can I connect to the board via serial.  I need to load program data on the board.  I will not be using it with a UNo but standalone with only a relay board attached.
Are some of the other pins on edge the same as the TX RX and RTS Ground, power etc.
