Topic: [SOLVED] is there standard for the Arduino language, or based on Arduino does (Read 1 time) previous topic - next topic
curious48
I really interested to know, have you started programming in Arduino? After seeing the threads pointed by @Robin, seems like you are confused a lot and shows a lack of experience in programming.
I suggest give some time to learn programming, if your interest is in Arduino, give it a try.
Understand a little bit about compilers in general is also a worth.
Yes, I programmed in Arduino.  I also programmed in C++ more than 5 years before Arduino existed (if we take 2004 as the earliest possible date since that's when Wiring was created).
I did not realize that the Arduino language was the C++ language.  (Not a dialect/a patois/a version of/a subset of).  The reason I didn't realize this is because it's not stated clearly.
@marco_c - those were some great examples of beginner trip-ups!!  Thanks a lot.
EDIT: I've now written up what I've learned in this "35-second Arduino language reference for expert programmers".  Thanks for everyone who contributed.
Are you curious about the intersection of Arduino/Electronics/Raspberry Pi/Orange Pi/Beaglebone/niche manufacturing/starting from 0 and scaling?  Try: http://curious.boards.net
