Topic: no sketch upload possible to Adafruit feather M0 express (Read 510 times) previous topic - next topic
tito-t
hey,
although I am quite sure to have been installing correctly, no sketch upload to Adafruit feather M0 express is possible:
I am using IDE  1.8.2 (also tried: 1.6.12 and 1.8.2/3 nightly build)
I installed Arduino M0  boards by the board manager
I added the Adafruit path to preferences text
I installed Adafruit M0 boards by the board manager
I installed Adafruit Windows 7 drivers
Plugging the Feather M0 express, it is clearly listed in the device manager
e.g., COM7 Adafruit Feather M0 express
I can choose Adafruit Feather M0 express board in the IDE,
I can see and choose the activated port COM7 (it's the only one which is listed, but without further board specification, just COM7, and it vanishes when I unplug the Feather, so it's supposed to be the right one though)
I tried the simple examples sketch
Blink.ino
it compiles fine,
but upload fails:
Code: [Select]
PORTS {COM7, } / {COM7, } => {}
Uploading using selected port: COM7
No device found on COM7
Set binary mode
readWord(addr=0)=0x5342
readWord(addr=0xe000ed00)=0
readWord(addr=0x400e0740)=0x55000000
version()=SBS00000,4#
chipId=0x55000000
Unsupported processor
Send auto-baud
Set binary mode
readWord(addr=0)=0x342c3034
readWord(addr=0xe000ed00)=0x53550023
readWord(addr=0x400e0740)=0x30455342
version()=740,4#
chipId=0x30455342
Unsupported ARM7TDMI architecture
Beim Hochladen des Sketches ist ein Fehler aufgetreten
what am I doing wrong or what am I missing?
ltheoret
In the IDE did you also install "Arduino SAND boards". It will not program without that. The Adafruit Feather M0 driver or what ever works off the "Arduino SAND boards" compiler. I have some and they work well.
Luc
Adiamus
I have the same Problem.
I have three Feather's, 2 M0 with RFM69 radio and one express.
The two with the RFM Module are just working great but the express ...
Same Problems as describt; additional if you open the Com Port, it writes "USBS".
The NeoPixel is green, the red LED is fading in and out ...
Adiamus
hey,
Blink.ino
it compiles fine,
but upload fails:
Code: [Select]
Set binary mode
chipId=0x55000000
Send auto-baud
Set binary mode
version()=740,4#
chipId=0x30455342
I have News.
There is a bug in the Bootloader - next step -> i will try to upload code with my linux machine.
Adiamus
Adiamus
Last Update from me in this Post:
I get it working with my Linux. I've updatet the bootloader and boot the pc back in Win7 and nothing ...
Seems not working with Windows. Back in Mint 17 I installed Circuit Python and what can I say ... it's just working.
Greetings
Leo
tito-t
Update: it was a hardware issue, the Feather was damaged from the start. I bought a new one and this one is fine now.
