Topic: Arduino Due Can Library (Read 507 times) previous topic - next topic
clash90
Hello,
I am using a custom board which is very similar to Arduino Due (uC ATSAM3x8E) and I want to program it using the arduino IDE (for many reasons I stopped using the Atmega IDE - too many bugs). So I have to implement the CAN communication between two boards. I succeeded with the Teensy 3.2 and another board using a CAN transceiver and the flexcan library. For Arduino Due, this library is not working. It is throwing this errors:
error: 'CORE_PIN3_CONFIG' was not declared in this scope
error: 'PORT_PCR_MUX' was not declared in this scope
And so on. I am pretty sure this is due to the fact that Flexcan is not meant to be used with arduino boards. Am I right? If I select the teensy 3.2 I can build without any errors. My question is, if there is out there a CAN library I can use with my Arduino Due which works in a similar way as the flexcan does?
Thanks
Claudio
Coding Badly
Please do not cross-post.  Other thread removed.
clash90
Yes sorry. I thought I deleted the first one since this is the most appropriate section. Sorry again
ard_newbie
#3
Jun 14, 2017, 11:11 am Last Edit: Jun 14, 2017, 11:40 am by ard_newbie
The DUE_CAN Library from collin80 is the right one:
https://github.com/collin80/due_can
