Topic: [Solved] Pinout of MKR1000 J3 connector? (Read 563 times) previous topic - next topic
Miq1
Jul 10, 2017, 12:33 pm Last Edit: Jul 10, 2017, 03:22 pm by Miq1
I am about to revive my MKR1000 by flashing a new bootloader with Atmel Studio 7 and the ATMEL-ICE programmer.
As the 10-pin programming port on the MKR1000 seems to have no indication of pin 1 whatsoever: what is the correct orientation to plug the programming connector from the ICE? Red wire towards the WiFi module or opposite?
[Solution] the red wire (pin 1) has to be closest to the silver WiFi module.
I tried it, was fortunate the chip was not fried when having it wrong at the first attempt and succeeded with the second :-)
Arduino_Genuino
Hi, actually you can't burn it :) the ATMEL ICE LED becomes green when connections are right and red otherwise so don't worry. The ATMEL ICE doesn't apply a voltage to power the chip, but it just senses it
