Topic: then //How do you declare “then” in this scope? (Read 3053 times) previous topic - next topic
JackOWalden1Sr
const int switchPin = 8;
unsigned long previousTime = .0152;
int switchState = .0152;
int prevSwitchState = .0152;
int Time = 2;
long interval = 1;
  for(int x = 2;x<8;x++){
    pinMode(x, OUTPUT);
    then == switchPIN
  int then == pinMode
  pinMode(switchPin, OUTPUT);
  if (A0 == HIGH, then, switchPin 7 == HIGH;
  if (A1 == HIGH, then, switchPin 6 == HIGH;
  if (A2 == HIGH, then, switchPin 2 == HIGH;
  if (A3 == HIGH, then, switchPin 3 == HIGH;
  if (A4 == HIGH, then, switchPin 4 == HIGH;
  if (A5 == HIGH, then, switchPin 5 == HIGH;
  //How do you declare "then" in this scope?
Robin2
This does not make sense
Code: [Select]
int then == pinMode
because pinMode() is a function that sets the mode of an I/O pin
You need to declare a variable before you use it. So you would need to have
Code: [Select]
int then;
before the line
Code: [Select]
then == switchPIN
But the word "then" seems a most unintuitive name for a variable and I have no idea why you want two variables (then and switchPIN having the value 8 )
Maybe you mean something like
Code: [Select]
then = digitalRead(switchPin);
All of the Arduino functions are explained in the Reference section
Another good way to learn is to study the many examples that come with the Arduino IDE
...R
PS  please post your program using the code button </>
Code: [Select]
so it looks like this
. See How to use the Forum
And if you have more questions about this project please continue them in this Thread.
Two or three hours spent thinking and reading documentation solves most programming problems.
larryd
Do you know what an integer is?
Do you know what an analog pin is?
No technical PMs.
The last thing you did is where you should start looking.
larryd
Always show us your current compete sketch.
Use CTRL T to format the sketch.
Please use code tags.
Use the </> icon in the posting menu.
[code] Paste sketch here. [/code]
No technical PMs.
UKHeliBob
Your question and code raise many questions.
Let's deal with a simple one.  Examine this code
Code: [Select]
if (digitalRead(A0) == HIGH)  //test whether pin A0 is HIGH
  //execute the code between the curly brackets if the test above returns true.
Does that go any way towards any part of your questions ?
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
INTP
You can't make up your own language and expect the program to understand. Take a few minutes looking at example code and see how they work.
JackOWalden1Sr
//Proof read this?...this creates error code:exit status 1...'digitalread' was not declared in this scope.
  int Time = 2;
  long interval = 1;
  for (int x = 2; x < 8; x++) {
    pinMode(x, OUTPUT);
  int switchPin = pinMode;
  int then();
  then == switchPin;
  if (digitalread(A0) == HIGH {switchPin 7 == HIGH};
      if (digitalread(A1) == HIGH {switchPin 6 == HIGH};
            if (digitalread(A2) == HIGH {switchPin 2 == HIGH};
                  if (digitalread(A3) == HIGH {switchPin 3 == HIGH};
                        if (digitalread(A4) == HIGH {switchPin 4 == HIGH};
                              if (digitalread(A5) == HIGH {switchPin 5 == HIGH};
  unsigned long currentTime = millis();
  int Time = 2;
  long interval = 1;
larryd
No technical PMs.
larryd
Should be more like:
if (digitalread(A0) == HIGH)
   switchPin 7 = HIGH;
Do you know what an 'integer' is?
No technical PMs.
slipstick
1. You can't assign a value of .0152 to an int, int means integer. Decimals aren't integers.
2. You need to know the difference between an assignment (=) and a comparison (==). Then you might realise at least one reason why "then == switchPin;" makes no sense.
3. When you open brackets you need to close them. Unlike in all your if statements.
4. "{switchPin 7 == HIGH} and its variants are gibberish. You're apparently comparing 7 with HIGH and then doing nothing with any result.
Whatever language you're writing your code in it isn't one that any Arduino (or C++ programmer) is going to recognise.
Steve
larryd
No technical PMs.
INTP
JackOWalden1Sr
 unsigned long previousTime = 1520;
 int switchState = 1520;
 int prevSwitchState = 1520;
 int Time = 2;
 long interval = 1;
   pinMode(x, OUTPUT);
 int then();
 then == switchPin;
 if (digitalRead(A0) = HIGH);
 if (digitalRead(A1) = HIGH);
 if (digitalRead(A2) = HIGH);
 if (digitalRead(A3) = HIGH);
 if (digitalRead(A4) = HIGH);
   switchPin 4 == HIGH
 if (digitalRead(A5) = HIGH);
   int Time = 2;
   long interval = 1;
 //How do you declare "then" in this scope?...This is "hung up" on switchPin 5
larryd
 This:
Should be:
 if (digitalRead(A1) == HIGH);  <-----<<<<< two =
   switchPin 6 = HIGH; <-----<<<<< one =
There is no function called:    then()
int then();  <-----<<<<< Tell us what you think is happening here.
then == switchPin; <-----<<<<< use one  =  but you should use names that mean something.
You really should master some of the basic examples that are installed with the IDE.
No technical PMs.
larryd
Read this:
https://www.arduino.cc/en/Reference/Assignment
And read this:
https://www.arduino.cc/en/Reference/If
For each { you need a }
What are you trying to do with the sketch ?
No technical PMs.
