Topic: then //How do you declare “then” in this scope? (Read 4175 times) previous topic - next topic
INTP
Troll or very 'analogWrite(ledPin, 1); //active high LED' individual.
johnwasser
// How do you declare "then" in this scope?...  This is "hung up" on switchPin 5
You don't.
Since you don't know how to program and have said that you don't want to learn and you can't pay someone to do the programming you are in for a heap of trouble.  You seem to be typing in nearly random strings of symbols and then asking how to fix your code.
I have fixed your code to make it compile.  This involved adding some missing declarations, adjusting the symbols to match the apparent intent, and commenting out several lines of complete nonsense, particularly the use of "then".  Your code still does nothing but at least it compiles with only warnings, not errors.  :)
Code: [Select]
boolean switchPin2, switchPin3, switchPin4, switchPin5, switchPin6,  switchPin7;
  unsigned long previousTime = 1520;
  int switchState = 1520;
  int prevSwitchState = 1520;
  int Time = 2;
  long interval = 1;
  for (int x = 2; x < 8; x++) {
    pinMode(x, OUTPUT);
  // int switchPin = pinMode;
  // int then();
  // then == switchPin;
  if (digitalRead(A0) == HIGH)
    switchPin7 = HIGH;
  if (digitalRead(A1) == HIGH)
    switchPin6 = HIGH;
  if (digitalRead(A2) == HIGH)
    switchPin2 = HIGH;
  if (digitalRead(A3) == HIGH)
    switchPin3 = HIGH;
  if (digitalRead(A4) == HIGH)
    switchPin4 = HIGH;
  if (digitalRead(A5) == HIGH)
    switchPin5 = HIGH;
  unsigned long currentTime = millis();
  int Time = 2;
  long interval = 1;
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
johnwasser
lastchancename
Very generous @johnwasser
I'm not entirely sure if the OP is a troll or not, but certainly needs a lot of help understanding the very basics.
Should send him off to Arduino kindergarten ASAP
Ask the right question, which can be hard for beginners, but this doesn't mean that google is broken.
Experienced responders have a nose for laziness, (they were beginners once)... expecting the poster to contribute to the learning experience.
UKHeliBob
Quote
if (digitalRead(A1) = HIGH);
   switchPin 6 == HIGH;
Should be:
 if (digitalRead(A1) == HIGH);  <-----<<<<< two =
   switchPin 6 = HIGH; <-----<<<<< one =
Should be
Code: [Select]
if (digitalRead(A1) == HIGH)  //no semicolon at the end of the statement
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
Robin2
I smell a troll.
+1
In this Thread the OP said " I spent my adult life in Silicon Valley;" and it is very difficult to imagine how anyone with a professional knowledge of computing (no matter how long ago) could ask questions like in this Thread.
Of course he might have been selling doughnuts to the geeks.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
johnwasser
If you look at the LinkedIn link I posted you will see that he was supervising the HVAC technicians and other facilities maintenance people.  May never have talked to a programmer in his 36-year career.
Robin2
That figures. But then his reference to his time in Silicon Valley was misleading. I have no idea whether that was intentional, but it was certainly careless.
...R
JackOWalden1Sr
// Its Hard Teaching an Old Dog New Tricks. Thanks John for checking on me. Also, thanks for all input.
// Please see attachments...the intent is to place this, as a working file, into the Microcontroller.
Code: [Select]
unsigned long previousTime = 848;
int switchState = 152;
int prevSwitchState = 848; // Not sure of these 3 lines...the intent is to time the outputs a small fraction of a second.
int Time = 1;
long interval = 1;
for (int x = 1; x < 8; x++) { // Not sure of these 3 lines either...see above…please explain "x+++...MS language?
  pinMode(x, OUTPUT);
int then();
then = switchPin;
if (digitalRead(A0) = HIGH);
  switchPin 7 == HIGH;
if (digitalRead(A2) = HIGH);
  switchPin 2 == HIGH;
if (digitalRead(A3) = HIGH);
  switchPin 3 == HIGH;
if (digitalRead(A4) = HIGH);
  switchPin 4 == HIGH
if (digitalRead(A5) = HIGH);
  switchPin 5 == HIGH;
  int Time = 2;
  long interval = 1;
aarg
Code: [Select]
You have the proper use of = and == reversed.
So it can't be "a working file".
  ... with a transistor and a large sum of money to spend ...
Please don't PM me with technical questions. Post them in the forum.
larryd
Please, this has been mentioned many times now!
Should Be!
if (digitalRead(A0) == HIGH);
switchPin 7 = HIGH;
An old dog should be able to still read ;)
Read this:
https://www.arduino.cc/en/Reference/Assignment
And read this:
https://www.arduino.cc/en/Reference/If
No technical PMs.
The last thing you did is where you should start looking.
larryd
x++   <-----<<<<< is the same as   x = x +1
  pinMode(x, OUTPUT);
This is making pins 1-7 OUTPUT pins.
This is your code after all.
No technical PMs.
UKHeliBob
There is so much wrong with the program that it is difficult to know where to start so let's start with the loop() function
Code: [Select]
    int Time = 2;
    long interval = 1;
What is it supposed to do apart from declaring and initialising 3 variables that are local to the function so will not be available anywhere else in the program, not that any other code will be executed anyway.
Another simple question.  Where is the end of the setup() function ?
JackOWalden1Sr
// My ignorance, I started with 2 OP programs, had to start somewhere...hopefully, see new attachment.
int Time = 1;
long interval = 1;
  pinMode(x, OUTPUT);
// Maybe the OUTPUT pins will work.
int then();
then = switchPin;
  switchPin 7 = HIGH;
  switchPin 6 = HIGH;
if (digitalRead(A2) == HIGH);
  switchPin 2 = HIGH;
if (digitalRead(A3) == HIGH);
  switchPin 3 = HIGH;
if (digitalRead(A4) == HIGH);
  switchPin 4 = HIGH
if (digitalRead(A5) == HIGH);
  switchPin 5 = HIGH;
  // The intent is to run the above program.
AWOL
Code: [Select]
if (digitalRead(A2) == HIGH);Lose the semicolon.
Use code tags.
Make sure you've got enough { and }, in the right places
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
