Topic: LCD not working on my laptop (Read 236 times) previous topic - next topic
Arjem
Hi! I'm having trouble with my LCD. So, my program runs perfectly on my friend's laptop. But when I tried running it on mine, the LCD just blink once then nothing happened. I have the same version of Arduino IDE as my friend's.
Attached below is my code.
photoncatcher
From the ino I see that you are using an i2c / backpack LCD display
As it works with your friend's laptop the hardware is OK. It might be that on your laptop a different library is installalled leading to non-funtioning of the LCD dsiplay.
I recommend Bill Perry's hd44780 library.
Succes !
Arjem
But I have copied all my friend's library and still not working
photoncatcher
Can you show pictures of your LCD - one picture of the front, one picture of the back ?
Nick_Pyner
#4
Aug 17, 2017, 06:32 am Last Edit: Aug 17, 2017, 06:33 am by Nick_Pyner
IF your codes are truly identical and it works on your friend's laptop
AND you have properly wired the gear together so that it doesn't fall apart in transit.
THEN about all that is left is the power supply, and it might be time to start talking about that....
Is anything changing there? Well quite possibly, and an LCD is just the thing to show it up.
