Topic: WiFi101 Client HTTP POST request fails after 3rd time (Read 774 times) previous topic - next topic
kida001
I would really appreciate any help, my home project has been put on hold for weeks as I haven't been able to figure this out. In a nutshell, I'm connecting to my wifi network, measuring temperature from a sensor, and sending that temperature data to a server via a HTTP Request. All of that stuff works.
I have it in a loop, and on the 3rd HTTP request I get 'Connection Failed' when it's trying to client.connect(server, 80) - I don't understand why it fails. I've tried adding client.stop() and client.flush() after each HTTP request, but nothing fixes it. Below is my sketch file with some of the temperature code removed to make it easier to read
Code: [Select]
#include <SPI.h>
#include <WiFi101.h>
#include <string.h>
#include <stdlib.h>
#include <OneWire.h>
#include <DallasTemperature.h>
//WiFi Client Setup
char ssid[] = "HIDDEN";    //  your network SSID (name)
char pass[] = "HIDDEN";       // your network password
int status = WL_IDLE_STATUS;    // the WiFi radio's status
char server[] = "HIDDEN";
WiFiClient client;
// Setup for temperature sensor
#define ONE_WIRE_BUS A5
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
DeviceAddress insideThermometer;
  WiFi.setPins(8,2,A3,-1);
  while (!Serial) {
    Serial.println("Waiting for serial");
  //Connect to wifi shield
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    while (true);
  wifiConnect();
  sensors.begin();
  while (client.available()) {
    char c = client.read();
    Serial.write(c);
  Code to get temperature here
  httpRequest(temp);
  delay(10000); // 5min
void httpRequest(String temp) {
  String request = "POST /api/webhooks/temp?temperature=" + temp + " HTTP/1.1";
  // if there's a successful connection:
  if (client.connect(server, 80)) {
    Serial.println("connected to server");
    client.println(request);
    client.println("Authorization: Token HIDDEN");
    client.println("Host: HIDDEN");
    client.println("Connection: close");
    client.println();
  else {
    Serial.println("Connection failed");
void wifiConnect() {
  //Attempt to connect to WiFi network:
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    status = WiFi.begin(ssid, pass);
  Serial.println("You're connected to the network");
kida001
Posted my answer here: https://forum.arduino.cc/index.php?topic=494968.0
henrikkoch
The real reason for this is that you need to update the WiFi101 firmware on the board. Then the problem totally disappears. I have spend hours to find the reason - and tried to prevent it with all kinds of tricks.
But follow this guide and it works like a charm:  https://www.arduino.cc/en/Tutorial/FirmwareUpdater
