Topic: I2C between Arduino Due and Nano (Read 147 times) previous topic - next topic
vishnu8861
Hello,
I'm trying to communicate between two Arduino Due and Nano. Nano as Master and Due as a slave. As given in the library description "Wire.h" When the master request for data from the slave, first it goes to Request Handler.
Code: [Select]
Wire.onRequest(requestEvent)
But when compile the program for Arduino Due I get following errors.
Code: [Select]
In file included from C:\Users\\Slave_Test3.ino:14:0:
C:\Users\..\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\libraries\Wire\src/Wire.h:59:7: error:   initializing argument 1 of 'void TwoWire::onRequest(void (*)())' [-fpermissive]
 void onRequest(void(*)(void));
But If I change from Arduino Due to any other board during the target of compile this error does not come.
Thank you
avr_fred
If you want help with a code problem, you must post all of your code, not just the offending line.
Please review the instructions for how to use the forum properly.
How to use this forum
