Topic: Port c code for ATmega48 to Arduino IDE for an Atmega328 (Read 192 times) previous topic - next topic
acitizen
I am hoping to use this example code that enables direct driving a glass LCD with a microcontroller. It is written in C for the ATmega48 microcontroller.
- What is needed to adapt the code for use in an ATmega328 (pro mini).
- Is this possible in the Arduino IDE, or is there a better method to use?
Link to document with details: http://www.atmel.com/Images/doc8103.pdf
Code: [Select]
// File name: LCX_App_Note_5_3_05.c Demo C code to run Pacific Displays' PPD-332 3 1/2 digit LCD
// Compiled with CodeVision AVR, version 1.24.4a Evaluation version, available from http://www.hpinfotech.ro
// This program displays 4 incrementing decimal digits on the LCD.LCD has 4 COMs and 8 segment connections (12 total)
// COM1-COM4 outputs on PORTD
//Segment Outputs on PORTC, called 1A, 1B, 2A, 2B, 3A, 3B to match A&B values in segment_table array
// The PD-332 has identical LCD wiring for each of 3 digits; 2 segment pins per digit, labeled A and B
#include <mega48.h>
unsigned char segs_out = 0;
unsigned char state_counter = 8;
unsigned char output_change = 0;
unsigned char LCD_d_1 =0; // counter starts at "000"
unsigned char LCD_d_2 =0;
unsigned char LCD_d_3 =0;
unsigned char LCD_d_4 =0;
unsigned char Pt_1_sec =0; // 0.1 second counter
// Prototypes defined below
void initialization(void);
#define debug 0
#define LCD_Driver 1
// Look Up Table (LUT) for 3 1/2 digit/4 COM LCD by Pacific
Displays, #PD-332
// The following table has 10 entries to display chars 0-9. Hex
values are COM1-COM4 for LCD inputs A & B.
const unsigned char segment_table[] =
{0x77,0x22,0xDB,0x97,0x2E,0x6D,0x7C,0x23,0xFF,0x2F}; //display
numbers 0-9
//************************Timer 0 overflow interrupt service
routine***********************
interrupt [TIM0_OVF] void timer0_ovf_isr(void)
// Re-load Timer 0 value
TCNT0=5; //Timer0 period = 0.125 usec = 8MHZ/64. 2msec = 8
usec*250 5 = 255-250 5/4/05
 state_counter++;
 output_change = 1; // This is a flag for main loop
 if (state_counter > 7) state_counter = 0;
//*********************End of Interrupt Service Routine*************************************
//**********************Main Begins here****************************************************
void main(void) {
//* * * * * Call Initialization function * * * * * *see functions defined below* * * * * * *
initialization();
//* * * * * * * Eanble Global enable interrupts* * * * * * * * ** *
#asm("sei")
//**********The following infinate While Loop contains the Switch statement for LCD refresh******
#if LCD_Driver
    while (1)
     if(output_change){
     output_change = 0;
    // The following state_counter generates the 4 COM output waveforms via PORTD, each with HI and LOW outputs
     switch (state_counter) {
         case 0: {
             segs_out = (segment_table[LCD_d_1]& 0x03); //get digit_1's A & B bits
             segs_out = segs_out | ((segment_table[LCD_d_2]&0x03)*4); //get digit_10's A & B bits
             segs_out = segs_out | ((segment_table[LCD_d_3]&0x03)*16); //get digit_100's A & B bits
             segs_out = segs_out | ((segment_table[LCD_d_4]&0x03)*64); //get digit_1000's A & B bits
             DDRD = 0;
             PORTD = 0x00;
             PORTC = segs_out;
             DDRC = 0xFF; // always on
             DDRD = 0x01; //COM1 asserted LOW
         case 1: {
             PORTD = 0x01;
             PORTC = segs_out ^ 0xFF; // Compliment segment
            outputs
             DDRD = 0x01; //COM1 asserted High
         case 2: {
             segs_out = (segment_table[LCD_d_1]& 0x0C)/4; //get digit_1's A & B bits
             segs_out = segs_out | (segment_table[LCD_d_2]&0x0C);//get digit_10's A & B bits
             segs_out = segs_out | ((segment_table[LCD_d_3]&0x0C)*4); //get digit_100's A & B bits
             segs_out = segs_out | ((segment_table[LCD_d_4]&0x0C)*16); //get digit_1000's A & B bits
             DDRD = 0;
             PORTD = 0x00;
             PORTC = segs_out;
             DDRD = 0x02; //COM2 asserted LOW
         case 3: {
             PORTD = 0x02;
             PORTC = segs_out ^ 0xFF; // Compliment segment outputs
             DDRC =0xFF;
             DDRD = 0x02; //COM2 asserted High
         case 4: {
             segs_out = (segment_table[LCD_d_1]& 0x30)/16; //get digit_1's A & B bits
             segs_out = segs_out | ((segment_table[LCD_d_2]&0x30)/4);//get digit_10's A & B bits
             segs_out = segs_out | (segment_table[LCD_d_3]&0x30);//get digit_100's A & B bits
             segs_out = segs_out | ((segment_table[LCD_d_4]&0x30)*4);//get digit_1000's A & B bits
             DDRD = 0;
             PORTD = 0x00;
             PORTC = segs_out;
             DDRC = 0xFF;
             DDRD = 0x04; //COM3 asserted LOW
       case 5: {
           PORTD = 0x04;
           DDRC = 0xFF;
           DDRD = 0x04; //COM3 asserted High
       case 6: {
           segs_out = (segment_table[LCD_d_1]& 0xC0)/64;//get digit_1's A & B bits
           segs_out = segs_out | ((segment_table[LCD_d_2]&0xC0)/16); //get digit_10's A & B bits
           segs_out = segs_out | ((segment_table[LCD_d_3]&0xC0)/4); //get digit_100's A & B bits
           segs_out = segs_out | (segment_table[LCD_d_4]&0xC0); //get digit_1000's A & B bits
           DDRD = 0;
           PORTD = 0x00;
           // PORTC = 0x00;//LCD_d_3 ^ 0xFF; // Compliment segment outputs
           PORTC = segs_out;
           DDRC = 0xFF;
           DDRD = 0x08; //COM4 asserted LOW
       case 7: {
           PORTD = 0x08;
           PORTC = 0x55;
           // PORTC = 0xFF; //LCD_d_3;
           DDRC = 0xFF;
           DDRD = 0x08; //COM4 asserted High
       default: DDRC = 0;
       DDRD = 0; // COM1-COM4 float
      // Increment a counter to measure out 0.1 sec
       Pt_1_sec++;
       if (Pt_1_sec >=50){//.1 sec
       Pt_1_sec = 0;
       LCD_d_1++; // 3 1/2 digit ripple BCD counter
      for LCD digits
            if (LCD_d_1 >=10){
           LCD_d_1 = 0;
           LCD_d_2++;}
           if (LCD_d_2 >=10){
           LCD_d_2 = 0;
           LCD_d_3++;}
           if (LCD_d_3 >=10){
           LCD_d_3 = 0;
           LCD_d_4++;}
       }  // end .1 sec
 // ****************End of Switch Statement************************
#endif
//***********************End of infinite While loop**********************************
//***********************End of Main*************************************************
//************************Initialization function defined here***********************
void initialization(void) {
    // Declare your local variables here
    // Crystal Oscillator division factor: 1
    CLKPR=0x80;
    CLKPR=0x00;
    //DDRC=0x7F; //7 Segment outputs
    // Timer/Counter 0 initialization
    TCCR0A=0x00;
    TCCR0B=0x03; // = 8MHz/64 3/22/05
    TCNT0=0xC1;
    // External Interrupt(s) initialization
    // INT0: Off
    // INT1: Off
    // Interrupt on any change on pins PCINT0-7: Off
    // Interrupt on any change on pins PCINT8-14: Off
    // Interrupt on any change on pins PCINT16-23: Off
    EICRA=0x00;
    EIMSK=0x00;
    PCICR=0x00;
    // Timer/Counter 0 Interrupt(s) initialization
    TIMSK0=0x01;
    // Timer/Counter 1 Interrupt(s) initialization
    TIMSK1=0x00;
    // Timer/Counter 2 Interrupt(s) initialization
    TIMSK2=0x00;
    // Analog Comparator initialization
    // Analog Comparator: Off
    // Analog Comparator Input Capture Dy Timer/Counter 1: Off
    //************************End of Initialization function***************************
hansibull
The ATmega48 and ATmega328 are pretty much compatible. Simple replace #include <mega48.h> with #include <mega328.h>, and you should be good to go. However, I see you're using Codevision AVR. Don't expect any support from the Arduino forum as we use avr-gcc instead
MightyCore -  ATmega1284, mega644, mega324, mega164, mega32, mega16, mega8535
Github.com/MCUdude/MightyCore
MiniCore - ATmega8, mega48, mega88, mega168, mega328
Github.com/MCUdude/MiniCore
DrAzzy
Well, if compiling with the IDE, he should remove the #include <mega48.h> and not replace it with anything - as the IDE handles including the chip-specific includes.
I think very little effort would be required to port that code
ATtiny core for 841+1634+828 and x313/x4/x5/x61/x7/x8 series Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts (some assembled), mosfets and awesome prototyping board in my store http://tindie.com/stores/DrAzzy
hansibull
As far as I can see the only changes will be the inline assembly and interrupt routines
acitizen
When I replace the #include <mega.48.h> with #include <mega328.h> it cannot find the mega328.h file (guessing I don't have this - quick google gives me no results in locating it)
Well, if compiling with the IDE, he she  should remove the #include <mega48.h> and not replace it with anything - as the IDE handles including the chip-specific includes.
If I leave out the #include statements it still won't compile. Has various issues with the syntax - I have not worked with pure C in the Arduino IDE before - is there a complementary code that I need to include?
The code is directly from the example PDF - I don't have any experience with codevision AVR - so hoping to avoid using it and work directly with Arduino IDE.
westfw
Quote
They aren't THAT different, but you will have to change a few things.
Omit this line.  As others have said, the equivalent is already done for you by the Arduino IDE:
Code: [Select]
#include <mega48.h>
Replace this line defining the interrupt:
Code: [Select]
// change to:
ISR(TIMER0_OVF_vect)
And replace the following:
Code: [Select]
#asm("sei")
// with
   sei();
Note that this use of timer0 is not compatible with the arduino core, so if you're hoping to eventually add an LCD to an arduino project, you'll need to do additional work.
