Topic: Nixies: stupid questions. (Read 24981 times) previous topic - next topic
cowjam
I googled for it.  Not sure I had a datasheet for my actual nixies, but I got the datasheet for the chips (which came with the nixies) by googling, and this is it: http://cowjam.co.uk/arct/k155id1.pdf
I've got some IN-35s which are just neon bulbs and they run fine at 180v (or whatever my circuit is running at) and ran fine with or without a 33k ohm resistor.
These ones: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=390206146006&ssPageName=STRK:MEWNX:IT#ht_864wt_905
FEDERICO
We bought nixies from the same vendor :-)
Mine are those
http://cgi.ebay.it/ws/eBayISAPI.dll?ViewItem&item=400174245756&ssPageName=STRK:MEWNX:IT
I am going to try to drive them at 170v and see...
After reading about your experience I was thinking that multiplexing and optocouplers should be the safest way...
Federico - Sideralis
Arduino &C: http://www.sideralis.org
Foto: http://blackman.amicofigo.com
cowjam
Yeah, optocouplers are the way to go!
If I figure out what happened I'll report back on here.
wyager
#18
Jan 29, 2011, 08:31 pm Last Edit: Jan 29, 2011, 08:34 pm by wyager Reason: 1
BTW guys, small neon bulbs should have at least 100K resistors (some use 200K) at 170+V or else they could burn out themselves or your circuit. I am able to multiplex them at 170v with a 100K resistor. Remember that the gas inside them will change its resistance until the voltage across the lamp is the sustaining voltage. A 200K resistor (which is probably better for long life) makes them look a little sputtery.
My A1As regulate themselves at 60V, which means that 110V gets dropped over the anode resistor. 110V/100000?=1.1mA. Almost twice the recommended amount, but I figure since I'm multiplexing... Still probably not healthy.
FEDERICO
wyager, thanks a lot for the advice. I am going to follow it!
cowjam
This ^ !
wyager
No problem. Also, 666 posts cowjam.  8)
FEDERICO
the number of the beast  ]:D
By the way i see that you (wyager) use a lot of transistors for driving your project. Don't you have a 74141 off hand?
ps. the optocouples i need, TLP627, are damn expensive  :smiley-eek-blue:
wyager
I was basing my project off parts I could get from digikey and I couldn't find any HV nixie drivers. The MPSA42s were only like 5 bucks for 25 IIRC, so I just went with those. I suppose after the shift registers and resistors and perfboard, the 74141s off ebay would have been cheaper, but it was a learning experience anyway.  :P
BTW, are the optocouples to protect the rest of the circuit from high voltage?
cowjam
I don't know if this will have contributed to the burnout, but I have discovered that I'd got the pins all muddled.
The power and ground pins were fine, but I had misinterpreted the position of the nixie pins so that I had the number sequence reversed.
I had also failed to spot the utterly confusing layout of the logic pins on the IC.  If you look you'll see that the pins are labelled A, D, B, C (in that order).  The logic chart is labelled D, C, B, A.
I will have undoubtedly sent things to the IC that it wasn't expecting, though the logic chart says that should merely have resulted in no output.
FEDERICO
I need them for multiplexing the nixies. If I connect all the cathodes to the nixie driver IC then I need a way to switch on the 170v anodes. I am experimenting the tlc5940 but I can't let it manage the high voltage. That's way I tought about optocouplers connected to the high voltage anche my TLC to open and close the gate.
So the datasheed is wrong?? Anyway it looks like a strange way for burning an IC...
cowjam
No, the datasheet is fine. I hadn't read it properly.
cowjam
Another question: Ground sharing.
Do I share the ground for the 180v and 5v circuits?
FEDERICO
Just in time, I was going to ask the same question. I think that no, for what I can understand for driving for example the neon bulbs you have to ground them to the arduino with the high voltage mpsa42 transistor, right?
cowjam
I hope someone answers soon, I'm about to run another set up (using a shift register) and I don't to kill anything else.
Thing is, the 74141 has one ground pin and runs 5v and high volt so that must share a ground, right?
