Topic: leonardo micro changing usb polling rate (Read 865 times) previous topic - next topic
joedodo
I want to make a mouse using leonardo or micro. I haven't received any of them, yet. I believe the default polling rate (the rate it reports data to pc via usb) is 125Hz. Is there a way to change  this number?
Robin2
The source code for all of the Arduino libraries is included in the Arduino IDE.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
joedodo
So go to the library of the mouse, and edit with some ide and create a new one for my use? Just as simple as that? I thought it would require some in depth knowledge of the usb protocol. Thanks, will have a look at that.
Robin2
I have no idea. But it is worth investigating the simple options first.
...R
Paul_KD7HB
The serial data bytes ride on top of the USB protocol bytes.
Paul
