Topic: I'm having trouble about running 4 servos with arduino.  (Read 182 times) previous topic - next topic
ALTAYLI00
Hello!
 We're trying to build 4 degree of freedom robotic arm, but before I need to be able to run 4 sg90 servo motors with arduino, so I used an external power supply(9V Duracell alkaline). However, I can't run all of them at the same time. One of them is not working every time. I tried to change the servo motor and the pin but nothings happened. I used the codes and the circuit ehich are in this application. ( https://circuitdigest.com/microcontroller-projects/controlling-multiple-servo-motors-with-arduino)
By the way, I'm kind a new in the forum, and I don't know the rules properly. I read the how to use this forum  articles, but english is not my mother language, so if I made a mistake, please let me know.
jremington
As you have discovered, 9V batteries are useless for motors, especially servos, which require 5 to 6V.
Servos require a surprising amount of power. A good rule of thumb is 1 Ampere per servo, so a 5 to 6V, 4 Ampere power supply will handle 1 to 4 servos of most (but not all) types.
A 5xNiMH AA battery pack will handle 2 servos. Don't forget to connect the grounds.
neiklot
You're only supposed to ask a question once afaik.
My question is still the same as in your other thread:
Why are you running 5-6V servos off 9V?
terryking228
You need better power for sure...
The servos need 5 to 6 volts at perhaps 1 to 2 amps.  So separate external power supply is needed. 5V to servos, external power supply ground connected to Arduino ground.
For the arduino, separate power. Wall wart of equivalent, like 9V 1A to external power.
the 9V alkaline won't work.
You MAY be able to use 4 AA NiMH batteries to run both Arduino 5V and the servos.
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
ALTAYLI00
Thank you all for your helpful answers. I'll try your suggestions and inform you.
My other thread was deleted, because I wrote it in the false topic, so I couldn't read your question. Also, there was a 9v battery in the application which I shared with you. That's why I used it.
