Topic: Arduino DUE sends Midi-Clock by Interrupt. Tempo set with Encoder (Read 98 times) previous topic - next topic
roundseven
Hello,
this is a small sketch for people who want to send midi-clock with the DUE. I use a rotary encoder with button function for tempo setting and start-stop. I tested it with the Synthstrom Deluge and its working fine.
Code: [Select]
 * Midi Clock per interrupt on Serial1
 * Tempo set with a rotary encoder
 * Start/Stop with the encoder button.
 * See also pin reference Arduino DUE: https://www.arduino.cc/reference/en/language/functions/communication/serial/
#include <DueTimer.h>
#define ENCODER_OPTIMIZE_INTERRUPTS
#include <Encoder.h>
const int midiClock = 0xf8;    // midic clock pulse byte
const int startByte = 0xfa;    // midi clock start byte
const int stopByte = 0xFC;     // midi clock stop byte
// rotary encoder pins
const int SW = 22;
const int CLK = 24;
const int DT = 26;
// initializing the encoder object
Encoder Encoder(DT,CLK);
int encoderValue = 120;
int encoderValueOLD = 120;
// start bpm (beats per minute)
int bpm = 120;
long interval = 60000000 / (24 * bpm);
bool startclock = true;
  // midi baut rate
  Serial1.begin(31250);
  pinMode(SW, INPUT);
  // read encoder button by interrupt. RISING: interrupt when button up
  attachInterrupt(digitalPinToInterrupt(SW), midiclock_STARTSTOP, RISING);
  // initialize Encoder with 120bpm * 4. The function "encoder_READ()" divides the value by 4 for exacter performance
  Encoder.write(480);
  // initializing midi clock interrupt timer
  Timer1.attachInterrupt(send_MIDICLOCK);
  // initializing encoder interrupt timer dependent on the bpm value (better results than with a fix value)
  Timer2.attachInterrupt(read_ENCODER);
  Timer2.start(interval);
void update_TEMPO() {
  Timer1.start(interval);   // midi clock
  Timer2.start(interval);   // encoder
void send_MIDICLOCK() {
  if (startclock) {
    Serial1.write(midiClock);
void midiclock_STARTSTOP() {
  startclock = !startclock;
  if (startclock) {
    Serial1.write(startByte);
  else {
    Timer1.stop();
    Serial1.write(stopByte);
void read_ENCODER() {
  // works better when dividing the encoder value by 4. Maybe it depends on the used encoder type
  // and you have to use a differnet dividor
  encoderValue = Encoder.read() / 4;
  if (encoderValue != encoderValueOLD) {
    encoderValueOLD = encoderValue;
    if (encoderValue > 240) {
      // upper tempo limit
      encoderValue = 240;
      // bpm * 4 cause of encoderValue = Encoder.read() / 4;
      Encoder.write(960);
    else if (encoderValue < 40) {
      // lower tempo limit
      encoderValue = 40;
      Encoder.write(160);
    bpm = encoderValue;
    update_TEMPO();
  // main loop
roundseven
A version with the <RotaryEncoder.h> library. Better debouncing.
Code: [Select]
#include <RotaryEncoder.h>
const int SW = 46;
const int CLK = 48;
const int DT = 50;
RotaryEncoder Encoder(DT,CLK);
int bpm = 120;
 // midi baut rate
 pinMode(SW, INPUT);
 Encoder.setPosition(bpm);
 Timer0.attachInterrupt(send_MIDICLOCK);
 Timer1.attachInterrupt(read_ENCODER);
 Timer0.start(interval);   // midi clock
 Timer1.start(interval);   // encoder
 if (startclock) {
 if (startclock) {
 else {
   Timer0.stop();
 Encoder.tick();
 encoderValue = Encoder.getPosition();
     encoderValue = 240;
     encoderValue = 40;
   bpm = encoderValue;
   SerialUSB.println(bpm);
   update_TEMPO();
