Topic: avr-g++ : error: CreateProcess : No such file or directory (Read 132 times) previous topic - next topic
PierreYvesPortal
CreateProcess
I used Arduino for several years without any problem. But now, since some 15 days, I cannot verify or compile and get a message as:
avr-g++:error:CreateProcess:No such file or directory
This error message appears with any Arduino Uno (genuine or clone) or Mega
I use Windows 10 on my desk computer.
(On my portable I have no problem. All Arduino programs run correctly with Windows Vista)
It seems to be an uncompatibility with W10 on my desk computer.
Of course, avr-g++ exist, Path :Arduino>Hardware>tools>avr>bin !
On Google forums this problem seems to be existing since 2015...
But answers are not credible. Uninstalling Arduino and installing it again doesn't solve this problem, Can you help me? Thanks!
pert
Please do this (preferably with a minimal sketch):
  • (In the Arduino IDE) click File > Preferences
  • Check the box next to "Show verbose output during: > compilation
  • Click "OK"
  • Sketch > Verify/Compile
  • After the compilation fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
  • In a forum reply here, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
  • Press "Ctrl + V". This will paste the compilation output between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
If the length of the output exceeds the forum's 9000 character limit, save it in a .txt file and post it here as an attachment. If you click the "Reply" button you'll see the "Attachments and other options" link.
PierreYvesPortal
Code: [Select]
Arduino: 1.8.2 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\PierreYves\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\PierreYves\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\PierreYves\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10802 -build-path C:\Users\PIERRE~1\AppData\Local\Temp\arduino_build_57669 -warnings=none -build-cache C:\Users\PIERRE~1\AppData\Local\Temp\arduino_cache_107973 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\PierreYves\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.arduinoOTA.path=C:\Users\PierreYves\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.avrdude.path=C:\Users\PierreYves\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -verbose C:\Users\PIERRE~1\AppData\Local\Temp\untitled751637984.tmp\sketch_mar19a\sketch_mar19a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\PierreYves\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\PierreYves\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\PierreYves\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10802 -build-path C:\Users\PIERRE~1\AppData\Local\Temp\arduino_build_57669 -warnings=none -build-cache C:\Users\PIERRE~1\AppData\Local\Temp\arduino_cache_107973 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\PierreYves\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.arduinoOTA.path=C:\Users\PierreYves\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.avrdude.path=C:\Users\PierreYves\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -verbose C:\Users\PIERRE~1\AppData\Local\Temp\untitled751637984.tmp\sketch_mar19a\sketch_mar19a.ino
Using board 'uno' from platform in folder: C:\Users\PierreYves\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23
Using core 'arduino' from platform in folder: C:\Users\PierreYves\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23
Detecting libraries used...
"C:\Users\PierreYves\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\PierreYves\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23\cores\arduino" "-IC:\Users\PierreYves\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23\variants\standard" "C:\Users\PIERRE~1\AppData\Local\Temp\arduino_build_57669\sketch\sketch_mar19a.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Users\PierreYves\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\PierreYves\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23\cores\arduino" "-IC:\Users\PierreYves\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23\variants\standard" "C:\Users\PIERRE~1\AppData\Local\Temp\arduino_build_57669\sketch\sketch_mar19a.ino.cpp" -o "C:\Users\PIERRE~1\AppData\Local\Temp\arduino_build_57669\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\PIERRE~1\AppData\Local\Temp\arduino_build_57669\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\PierreYves\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10802 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Users\PierreYves\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23\cores\arduino" "-IC:\Users\PierreYves\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23\variants\standard" "C:\Users\PIERRE~1\AppData\Local\Temp\arduino_build_57669\sketch\sketch_mar19a.ino.cpp" -o "C:\Users\PIERRE~1\AppData\Local\Temp\arduino_build_57669\sketch\sketch_mar19a.ino.cpp.o"
avr-g++: error: CreateProcess: No such file or directory
exit status 1
Error compiling for board Arduino/Genuino Uno.
pert
This error indicates you need to take some drastic action. Be aware this is somewhat advanced and will remove any boards you have installed via Boards Manager:
  • In the Arduino IDE, click the link on the line following File > Preferences > More preferences can be edited directly in the file. This will open the C:\Users\PierreYves\AppData\Local\Arduino15 folder.
  • Delete all files and folders under the Arduino15 folder except for preferences.txt. Please be very careful when deleting things from your computer. When in doubt, back up!
  • Restart the Arduino IDE
Verify that you can now use your Uno before reinstalling any packages via Boards Manager.
pert
You're welcome. I'm glad to hear it's working now. Enjoy!
Per
